Post sensor data to firebase
Hi expert coders, am trying to post amg88 sensor data to firebase but fail. Below is the arduino code. Appreciate if anyone could advise? Thanks alot.
#include <ESP8266WiFi.h>
#include <FirebaseESP8266.h>
#include <Adafruit_AMG88xx.h>
#define WIFI_SSID "xxxxx"
#define WIFI_PASSWORD "xxxxx"
#define FIREBASE_HOST "xxxxx"
#define FIREBASE_AUTH "xxxxx"
FirebaseData fbdata;
FirebaseJsonArray fbarray;
void printResult(FirebaseData &data);
unsigned long sendDataPrevMillis = 0;
Adafruit_AMG88xx amg;
    WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
    Serial.print("Connecting to Wi-Fi");
    while (WiFi.status() != WL_CONNECTED)
        Serial.print(".");
        delay(300);
    Serial.print("Connected with IP: ");
    Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
    Firebase.reconnectWiFi(true);
    //Set the size of WiFi rx/tx buffers in the case where we want to work with large data.
    fbdata.setBSSLBufferSize(1024, 1024);
    //Set the size of HTTP response buffers in the case where we want to work with large data.
    fbdata.setResponseSize(1024);
    if (!Firebase.beginStream(fbdata, "room 1"))
        Serial.println("------------------------------------");
        Serial.println("Can't begin stream connection...");
        Serial.println("REASON: " + fbdata.errorReason());
   amg.begin();
   delay(100);
    if (millis() - sendDataPrevMillis > 1000)
        sendDataPrevMillis = millis();
        fbarray.clear();
        float pixels[AMG88xx_PIXEL_ARRAY_SIZE];
      amg.readPixels(pixels);
      //ret = "[";
  for(int i = 0; i < AMG88xx_PIXEL_ARRAY_SIZE; i++) {
      fbarray.add(pixels[i]) ;
        //if (i != AMG88xx_PIXEL_ARRAY_SIZE - 1) ret += ", ";
    //ret += "]";
        if (Firebase.set(fbdata,"room 1",fbarray))
            Serial.println("PASSED");
            Serial.println("PATH: " + fbdata.dataPath());
            Serial.println("TYPE: " + fbdata.dataType());
            Serial.print("VALUE: ");
            printResult(fbdata);
            Serial.println("FAILED");
        Serial.println("Get Array...");
    if (data.dataType() == "int")
        Serial.println(data.intData());
    else if (data.dataType() == "float")
        Serial.println(data.floatData(), 5);
    else if (data.dataType() == "double")
        printf("%.9lf\n", data.doubleData());
    else if (data.dataType() == "boolean")
        Serial.println(data.boolData() == 1 ? "true" : "false");
    else if (data.dataType() == "string")
        Serial.println(data.stringData());
    else if (data.dataType() == "json")
        FirebaseJson &json = data.jsonObject();
        //Print all object data
        Serial.println("Pretty printed JSON data:");
        String jsonStr;
        json.toString(jsonStr, true);
        Serial.println(jsonStr);
        Serial.println("Iterate JSON data:");
        size_t len = json.iteratorBegin();
        String key, value = "";
        int type = 0;
        for (size_t i = 0; i < len; i++)
            json.iteratorGet(i, type, key, value);
            Serial.print(i);
            Serial.print(", ");
            Serial.print("Type: ");
            Serial.print(type == FirebaseJson::JSON_OBJECT ? "object" : "array");
            if (type == FirebaseJson::JSON_OBJECT)
                Serial.print(", Key: ");
                Serial.print(key);
            Serial.print(", Value: ");
            Serial.println(value);
        json.iteratorEnd();
    else if (data.dataType() == "array")
        //get array data from FirebaseData using FirebaseJsonArray object
        FirebaseJsonArray &arr = data.jsonArray();
        //Print all array values
        Serial.println("Pretty printed Array:");
        String arrStr;
        fbarray.toString(arrStr, true);
        Serial.println(arrStr);
        Serial.println("Iterate array values:");
        for (size_t i = 0; i < fbarray.size(); i++)
            Serial.print(i);
            FirebaseJsonData &jsonData = data.jsonData();
            //Get the result data from FirebaseJsonArray object
            fbarray.get(jsonData, i);
            if (jsonData.typeNum == FirebaseJson::JSON_BOOL)
                Serial.println(jsonData.boolValue ? "true" : "false");
            else if (jsonData.typeNum == FirebaseJson::JSON_INT)
                Serial.println(jsonData.intValue);
            else if (jsonData.typeNum == FirebaseJson::JSON_FLOAT)
                Serial.println(jsonData.floatValue);
            else if (jsonData.typeNum == FirebaseJson::JSON_DOUBLE)
                printf("%.9lf\n", jsonData.doubleValue);
            else if (jsonData.typeNum == FirebaseJson::JSON_STRING ||
                     jsonData.typeNum == FirebaseJson::JSON_NULL ||
                     jsonData.typeNum == FirebaseJson::JSON_OBJECT ||
                     jsonData.typeNum == FirebaseJson::JSON_ARRAY)
                Serial.println(jsonData.stringValue);
    else if (data.dataType() == "blob")
        for (int i = 0; i < data.blobData().size(); i++)
            if (i > 0 && i % 16 == 0)
            if (i < 16)
                Serial.print("0");
            Serial.print(data.blobData()[i], HEX);
            Serial.print(" ");
    else if (data.dataType() == "file")
        File file = data.fileStream();
        int i = 0;
        while (file.available())
            int v = file.read();
            if (v < 16)
                Serial.print("0");
            Serial.print(v, HEX);
            Serial.print(" ");
            i++;
        file.close();
        Serial.println(data.payload());
