Post String to Web Service SQL
I have web service that run on my server, the web service is provide communication with SQL database server. I must send a string that contain SQL syntax to that web service.
Anyone can help me how to post a string to a web service?
Is it reasonable to assume that you have an Ethernet shield?
Is it reasonable to assume that you know how to make a POST request?
Yes, i have a ethernet shield.
I dont know how to post request with a long string like this:
"INSERT INTO [dbAuto].[dbo].[test] ([dept_id],[rpo_id],[qty_auto],[date_in]) VALUES ('" & "ROP2OUT" & "','" & txt_rpo_no.Text & "','" & lbl_qty.Text & "','" & tgl & "')")
it alwasys error when i put that in string variable..
my web service located at ServerUrl = "http://192.168.0.79:250/Default.aspx"
You send the server a parameter with the value in it. The server does the SQL database insertion.
