Posting code
Hi everyone, I am having a small problem with my coding. Before I get into whats going on I have a question about putting coding on here. My code is to big and won't post, so how do I put it on so it can be looked at?
You could cut it down until it is small enough to post but still exhibit your problem.
Quite often, the process of doing this helps you solve the problem yourself.
You could use something like pastebin, I guess, but who would read hundreds of lines of someone else's code ?
Much better if you try to locate the code where the problem probably lies, and post that, or, better yet, write a trivial sketch that exemplifies the wrong behaviour you're seeing or the thing you don't understand.
You can attach the pde/ino file to a post, zipped up if necessary.
