Posting data to a database using Arduino
Hi everyone,
I have had my Arduino Uno for some months now and I am currently developing a 'credit card' payment system using RFID tags.
I am using an LCD screen, a keypad, the RFID sensor, and a buzzer and the program is working really well. Each card corresponds to a specific serial number and a user can add money to his account or buy items.
Now I want to post the money left in the account to a database every time a user makes a purchase. I then want to access the data using SQL and display on a website.
Would this be possible using ESP8266? I am not quite sure how you are supposed to send data to a database...
Kind regards and thank you in advance :slight_smile:
p.s. here is the code for my current program which stores the data locally.
#include <Wire.h>
#include <SPI.h>
#include <MFRC522.h>
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] = {
    {'1','2','3','A'},
    {'4','5','6','B'},
    {'7','8','9','C'},
    {'*','0','#','D'}
float nums[5] ={};
byte rowPins[ROWS] = {8, 7, 6, 5}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {A3, A2, A0, A1}; //connect to the column pinouts of the keypad
int decimal =0;
LiquidCrystal_I2C lcd = LiquidCrystal_I2C(0x27, 16, 2);
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
byte ledPin = 13;
#define RST_PIN         9          // Configurable, see typical pin layout above
#define SS_PIN          10         // Configurable, see typical pin layout above
float price = 0;
char MoneyLeft = 10;
MFRC522 mfrc522(SS_PIN, RST_PIN);
String value = "A9 A4 DE 8B";// Create MFRC522 instance
float cost = 0;
int c = 0;
boolean add =false;
int rs = 7;//lcd screen
int en=8;
int d4 = 3;
int d5= 4;
int d6= 5;
int d7 = 6;//lcd screen
int buzzPin = 2;
int buzztime = 500;
int t= 0;
float addition = 0;
const int buzzer =2;
boolean entered[4] = {};
String thirdscan;
String lastscan;
String serialnumbers[] = {"A9 A4 DE 8B", "0A FA 82 16"};
String names[] = {"Alex", "Marta"};
float account[] = {10, 20};
bool schoolLunch[] = {true, false};
 Serial.begin(9600);   // Initialize serial communications with the PC
  while (!Serial);    // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
  SPI.begin();
 lcd.init();
  lcd.backlight();// Init SPI bus
  mfrc522.PCD_Init();   // Init MFRC522
  mfrc522.PCD_DumpVersionToSerial();  // Show details of PCD - MFRC522 Card Reader details
  Serial.println(F("Scan PICC to see UID, SAK, type, and data blocks..."));
 pinMode(buzzer, OUTPUT);
  // Reset the loop if no new card present on the sensor/reader. This saves the entire process when idle.
lcd.setCursor(0,0);
  // Look for new cards
  if ( ! mfrc522.PICC_IsNewCardPresent())
    return;
  // Select one of the cards
  if ( ! mfrc522.PICC_ReadCardSerial())
    return;
  //Show UID on serial monitor
  Serial.print("UID tag :");
  String content= "";
  byte letter;
  for (byte i = 0; i < mfrc522.uid.size; i++)
     Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
     Serial.print(mfrc522.uid.uidByte[i], HEX);
     content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
     content.concat(String(mfrc522.uid.uidByte[i], HEX));
  content.toUpperCase();
  for (c = 0; c <= 1; c++){
       if (content.substring(1) == serialnumbers[c]) //change here the UID of the card/cards that you want to give access
        tone(buzzer, 1600);
        delay(100);// ...for 1 sec
        noTone(buzzer);
        lcd.clear();
        if (lastscan != content.substring(1)){
          lcd.print(names[c]);
          lcd.print("'s account:");
          lcd.setCursor(0,1);
          lcd.print(account[c]);
          delay(1500);
          lcd.clear();
          lcd.print("Scan again to");
          lcd.setCursor(0,1);
          lcd.print("buy something...");
        else{
          lcd.clear();
          delay(50);
     Serial.print("How much does this cost");
       lcd.print("Item Cost: ");
       lcd.setCursor(0,1);
int c=0;
    int key=0;
   float price = 0;
   int decimal = 0;
   int z=1;
   boolean add=false;
   for (z=1;z<=4;z++){
    nums[z] = 0;
    entered[z] = false;
  for (int x=1; x<=4; x++){
    int key = keypad.getKey();
    while(key == NO_KEY) {
    if (key >= 48 and key<=57){
      key = key-48;
      nums[x] = key;
      entered[x] = true;
    else{
      if (key==42){
        decimal =x;
      if (key==65){
        add=true;
      if (key==35){
 if (x-decimal==1 and decimal > 0){
  nums[x] = nums[x]/10  ;
 if (x-decimal==2 and decimal > 0){
  nums[x] = nums[x]/100  ;
 if (decimal == 0 and x ==2){
  nums[1] = nums[1]*10;
if (entered[x]){
  Serial.print(key);
else{
  if (decimal==x){
 int x=1;
   for (x=1;x<=4;x++){
    price += nums[x];
if (add==false){
  lcd.setCursor(0,1);
  lcd.print(price);
  Serial.println(price);
        if (add==true) {
          lcd.clear();
          lcd.print ("How much do");
          lcd.setCursor(0,1);
          lcd.print("you want to add?");
      key = key-48;
      nums[x] = key;
      entered[x] = true;
    else{
      if (key==42){
        decimal =x;
      if (key==65){
        add=true;
      if (key==35){
if (entered[x]){
  Serial.print(key);
  lcd.print(key);
else{
  if (decimal==x){
    lcd.print(".");
  if (decimal==3){
 int x =1;
   for (x=1;x<=4;x++){
    addition += nums[x];
          lcd.clear();
          lcd.print("Money added:");
          lcd.setCursor(0,1);
          lcd.print(addition);
          account[c] += addition;
          delay(1500);
          lcd.clear();
          lcd.print("Money in account:");
          lcd.setCursor(0,1);
          Serial.println(account[c]);
          delay(1500);
          lcd.clear();
          lcd.setCursor(4,0);
    lcd.print("Success!");
          addition = 0;
      else{
        delay(1500);
        lcd.clear();
      float money = account[c];
      if (money - price >= 0){
      float (money -= price);
      account[c] = (float)money;
    Serial.println(money);
    lcd.print("Money left: ");
    lcd.setCursor(0,1);
    lcd.print(money);
    delay(1500);
    lcd.clear();
    lcd.setCursor(4,0);
    else{
      lcd.print("Not enough");
      lcd.setCursor(0,1);
      lcd.print("money in account");
  thirdscan = lastscan;
  lastscan = content.substring(1);
  content.substring(1) ="";
In general to get data into a database you need to have a program "listening" for the Arduino which can receive the data and then save it to the database.
You could set up the database on a laptop (or a Raspberry Pi). You could connect to it using WiFi if you want a wireless connection (or using Bluetooth) or you could simply connect with the regular USB cable if wireless is not needed.
Do you you know how to write a program to save data in and retrieve data from an SQL database?
If you just want a simple database I suggest using SQLite which contains everything in a single database file
...R
yes, you can. You can connect directly ESP8266 to the database. (there is library for MySQL)
However, that is not a good way because of security. Exposing database to the outside is dangerous.
There is a better way . Arduino makes HTTPS request to the webserver, the Web server will interact with the database
Robin2:
...R
Thank you for your response, Robin. What program should I use to 'listen' to the Arduino?
I am still learning how to use SQL databases, but I was wondering whether the database could be stored on the web...
IoT_hobbyist:
There is a better way . Arduino makes HTTPS request to the web server, the Web server will interact with the database
How do you make an HTTPS request?? Do you have to use PHP??
Also, I was wondering how I would then send data from the webserver to the database.
IoT_hobbyist:
Can you provide more details please?
...R
alexoort:
The answer to the first part of the question depends (among other things) on where you want to have the database. I was assuming you would have it on a laptop or Raspberry Pi. If I was building it on this laptop I would write the program in Python.
Many (most?) of the internet hosting companies provide an SQL database as part of their package. I am not familiar enough with how that works to offer advice.
...R
alexoort:
From Arduino ESP8266, you can use a similar function of WiFi101SSLClient to make HTTPS request. On Webserver, you use PHP to handle the request from Arduino/ESP8266 and interact with the database. you can google "PHP MySQL" to see how
Robin2:
...R
A connection is created between Arduino/ESP8266 and MySQL. There are some library that you can find on the internet. For example, GitHub - ChuckBell/MySQL_Connector_Arduino: Database connector library for using MySQL with your Arduino projects.
IoT_hobbyist:
Thanks for the link. Interesting.
I guess if one is accessing an existing MySQL that someone else has set up for this it should be straightforward. However I would not want to have to create and debug SQL commands on an Arduino.
But as far as I an see the link does not explain how to install and set up MySQL. I did that in the past and I did not consider it simple - hence my preference for SQLite if all the features of MySQL are not required.
...R
