A member of my staff asked me to come up with a way to wirelessly keep track of temperatures for fifteen refrigerators around our facility. I knew about Phant from some conferences I've been to and thought it'd be a great way to keep track of data internally.
I've already got the server set up, and I've got some Sparkfun Blynk Boards (built in WiFi and temperature/humidity sensors), now I just need to code to connect them.
Here's the idea:
Access Wifi (WPA2)
Take a Temp
Post temp data to local Phant server. (Public key / Private Key)
Repeat every four hours.
My programming skills are atrocious and I just want to be done with this project. I'm paying $50.
Lonecoon:
Here's the idea:
Access Wifi (WPA2)
Take a Temp
I guess at this stage you are just wanting a simple "proof of concept" setup to demonstrate that the system is usable at a basic level.
It would not be difficult to achieve that. Sparkfun has even a test "Phant" channel which works without TLS, so it would be easy to demonstrate that something works.
You'd then want to check how a deployment of 15 devices would look like, and how it could be managed. Maybe different wireless lan credentials, maybe local firewalls preventing internet access, maybe only a remote sensor can be located in the refrigerator but not the whole device. Maybe power consumption is an issue etc. etc.
I don't have one of these Sparkfun Blynk Board - ESP8266 devices, so I can't get further involved, but wish you luck with it.
