Posting to Maker (IFTTT) using curl
[Sorry, posted previously to the wrong board]
Hi there
I’m trying to activate a Maker recipe on IFTTT to cycle my Philips Hue light on and off.
I’m using a curl command supplied by Maker. The command works fine through Terminal, but won’t fire the recipe through arduino.
Here’s the code. Any suggestions?
#include <Process.h>
#include <Wire.h>
#include <Console.h>
Process p;
  Bridge.begin();   // Initialize the Bridge
  Console.begin();
  // Wait for Console port to connect
  //  while (!Console);
    p.begin("curl -X POST https://maker.ifttt.com/trigger/Turn_Off/with/key/nYU642YiFwwuJApYyJTRBo2kXAWjEHAPieY9lG7grla");
    p.run();
    Serial.println("Turning Off");
      while (p.available()>0) {
    char c = p.read();
    Serial.print(c);
  // Ensure the last bit of data is sent.
  Serial.flush();
    delay(20000);
    p.begin("curl -X POST https://maker.ifttt.com/trigger/Turn_On/with/key/nYU642YiFwwuJApYyJTRBo2kXAWjEHAPieY9lG7grla");
    p.run();
    Serial.println("Turning On");
    char c = p.read();
    Serial.print(c);
  Serial.flush();
    delay(20000);
 Bridge.begin();  // Initialize Bridge
 Process p;
 p.begin("/usr/bin/curl");
 p.addParameter("-X");
 p.addParameter("POST");
 p.addParameter("https://maker.ifttt.com/trigger/Turn_Off/with/key/nYU642YiFwwuJApYyJTRBo2kXAWjEHAPieY9lG7grla");
 while (p.running());
 while (p.available()) {
    char c = p.read();
    Serial.print(c);
http://www.ibuyopenwrt.com/index.php/2-uncategorised/208-process-class-with-return-variable
