'Pot' question
Is it possible to write an int value as the value of a pot?
ie if pot value is 250; x=250?
in other words can you write the value of pot to value of x?
You mean assign the value of an analog pin reading that is connected to a pot? Yes, that's quite common...
The pot value is usually read in via analogRead() as a 10-bit number:
int pot;
pot = analogReading(Ax);
then you can manipulate from there:
potPWM = pot>>2 & 0xFF; // make it an 8-bit number
analogWrite (potPWM); // turn into 8-bit PWM output.
I had a brain fart before i posted it...walked away..came back and rewrote my code and fixed my problem.
so thanks for the responses.
