Potenciostat Code
Hello,
I'm a beginner im Arduino programing and I'm having dificulties to write a code to potenciometric mode and square wave voltammetry on a potenciostat/galvanostat that I'm development. If someone can help me, please, this is a ciclic voltammetry code that I just have.
Thanks!
// Cyclic Voltammetry
float CVstartVolt; //
float CVpeakVolt; //
float CVscanRate; //
int CVwaveType;
// Changing Resolution
float gain = 100.0;
// Changing Quiet Time (This is the time held at initial voltage before sampling begins)
float quietTime = 0.200;
int quietTimeMillis = round(quietTime*1000.0);
// Changing Sampling Speed
float sampleRateFloat;
int sampleRate;
int samplingDelay; //(value in µs) >> 1/samplingDelay = Sampling Rate
float samplingDelayFloat; //(value in µs) >> 1/samplingDelay = Sampling Rate
//---------------------------------------------------------------------------------Pin Assignments
const int refPin = A3; // Main Analog Input
const int readPin = A2; // Main Analog Input
const int outPin = A14;
const int sp4tOne = 11; // Resolution Switch 1
const int sp4tTwo = 10; // Resolution Switch 2
const int ledPin = 13; //LED pin
const int refCounterShortSwitch = 9; //in2
const int workingElectrodeSwitch = 8; //in4
const int counterElectrodeSwitch = 7; //in1
elapsedMicros usec = 0;
//---------------------------------------------------------------------------------Instructions
String inStruct; // Main instructions from USB
String twoStruct;
String threeStruct;
String fourStruct;
String fiveStruct;
String sixStruct;
double value = 0; // ADC reading value
double ref = 0; //Ref reading value
float aRef = 2.0468; // Analog Reference
float aRefMid = 0.0;
float DACaRef = 3.3;
float DCoffset = 0.0;//0.25/gain; //measured analytically
float DACaRefMid = (aRefMid + DCoffset)*4095.0/DACaRef;
float DACoff = aRef * 4095.0 / DACaRef;
float referenceElectrodeVoltage = 0.220;
//---------------------------------------------------------------------------------Setup
//#include <ADC.h>
//ADC *adc = new ADC(); // adc object
pinMode(ledPin, OUTPUT);
pinMode(readPin, INPUT);
pinMode(outPin, OUTPUT);
pinMode(sp4tOne, OUTPUT);
pinMode(sp4tTwo, OUTPUT);
pinMode(refCounterShortSwitch, OUTPUT);
pinMode(workingElectrodeSwitch, OUTPUT);
pinMode(counterElectrodeSwitch, OUTPUT);
analogWriteResolution(12);
analogReadAveraging(32);
analogReadRes(16);
float averageSum = 0;
for (int32_t i = 0; i < 50; i++) {
averageSum += analogRead(refPin) * aRef / 65535.0; // analog read == # out of 2^16
aRefMid = averageSum/50.0;
while (usec < 5000);
usec = usec - 5000;
//---------------------------------------------------------------------------------Main Loop
analogWrite(A14, DACaRefMid); //Maintain almost (small voltage due to op-Amp offset) zero at electrode.
digitalWrite(refCounterShortSwitch, LOW);
digitalWrite(workingElectrodeSwitch, HIGH);
digitalWrite(counterElectrodeSwitch, HIGH);
if (Serial.available()) {
// Interprets commands from computer
// All commands must be terminated with a comma ","
inStruct = Serial.readStringUntil('!');
twoStruct = Serial.readStringUntil('@');
threeStruct = Serial.readStringUntil('#');
fourStruct = Serial.readStringUntil('$');
fiveStruct = Serial.readStringUntil('%');
sixStruct = Serial.readStringUntil('^');
if (inStruct.startsWith("cycVolt")) {
CVstartVolt = twoStruct.toFloat();
CVpeakVolt = threeStruct.toFloat();
CVscanRate = fourStruct.toFloat();
CVwaveType = fiveStruct.toInt();
cycVolt();
What is the question?
Please read the "how to use the forum" stickies to see how to format and post code and some hints on how to ask an effective question.
What does that code do? How does that differ from what it is intended to do?
