Potential bug in strdio?
Amigos,
I found something i do not understand, so i will ask the question:
when running this program, the output is as expected
#include <stdio.h>
char  _line1[] = "0-0:1.0.0(190205140804W)";
char *_line2 = "0-0:1.0.0(190205140804W)";
  printf("\nBooting ...\n");
  printf("PF-_line1 = %s \n", _line1);
  Serial.print("SP-_line1 = ");
  Serial.println(_line1);
  printf("PF-_line1 = %s\n", _line1);
  printf("Booting ...\n");
output
11:29:43.653 ->
11:29:43.653 -> Booting ...
11:29:43.653 -> PF-_line1 = 0-0:1.0.0(190205140804W)
11:29:43.653 -> SP-_line1 = 0-0:1.0.0(190205140804W)
when changing the 2nd printf statement from printf(“PF-_line1 = %s \n”, _line1);
to printf("\nPF-_line1 = %s \n", _line1); this is the output. (added a newline in front of text)
11:47:35.643 ->
11:47:35.643 -> Booting ...
11:47:35.643 ->
11:47:35.643 -> SP-_line1 = 0-0:1.0.0(190205140804W)
11:47:35.643 -> PF-_line1 = 0-0:1.0.0(190205140804W)
Note the MISSING 2nd Line
what gives?
Regards,
Rob
That's exactly what I would expect. When you added the newline, what were you hoping would happen?
Bill,
what i would expect is
11:29:43.653 ->
11:29:43.653 ->
note the newline after the booting... message, that is what i expect.
thanks for your response,
Rob
That is weird, can you post the code that produces the second output?
that would be
#include <stdio.h>
char _line1 = “0-0:1.0.0(190205140804W)”;
char *_line2 = “0-0:1.0.0(190205140804W)”;
printf("\nBooting …\n");
printf(“PF-_line1 = %s\n”, _line1);
printf(“Booting …\n”);
note the \n before the PF-_line1 =, that is the only diference
regards,
Rob
BTW, Arduino V1.8.8
Which Arduino
Mark
ESP8266 (NodeMCU V3).
but there is no hardware specific stdio library, so i blame the compiler, not the h/w
Rob
Last time I had the need for “printf” I had to include printf.h in order to make it work, dunno if that is related to your problem.
#include <printf.h>
Albeit, unless you really need to use printf I suggest you use Serial.print instead. If you want to print multiple arguments in one line, you could use a macro:
#define PrintTwo(a, b) Serial.print(a); Serial.println(b)
or something like that.
EDIT: Sorry, this answer applies to the arduino and not the NodeMCU. I think… :slight_smile:
Danois90:
Or the more sensible thing anno 2019, a(n inline) function.
i may have spoken to soon, i did a search and found a plethora of stdio files related to 8266.
