Potentiometer & adafruit cc3000 wifi shield
What I’m trying to do: Push potentiometer data to mqtt broker via Arduino & Adafruit cc3000 wifi shield.
I got the potentiometer & wifi shield working separately but not at the same time. When running my code I only get value 1023 (i.e. max values) from potentiometer.
This forum has been very helpful when building my project(s) and “my” code below is somewhat copy&paste from several different project around here. So thanks for your help already! :slight_smile:
Would anyone have idea what is wrong? I’m using external 12V power supply for Arduino because wifi shield need the extra voltage to run - could this have something to do with my problem?
  This is an MQTT publish example for the Adafruit CC3000 Wifi Breakout & Shield (https://www.adafruit.com/products/1469).
  This script uses some of the methods from the buildtest example for CC3000 that Limor Fried, Kevin Townsend and Phil Burgess
  wrote for Adafruit Industries to make debugging easier.
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <cc3000_PubSubClient.h>
// These are the interrupt and control pins
#define ADAFRUIT_CC3000_IRQ   3  // MUST be an interrupt pin!
// These can be any two pins
#define ADAFRUIT_CC3000_VBAT  5
#define ADAFRUIT_CC3000_CS    10
// Use hardware SPI for the remaining pins
// On an UNO, SCK = 13, MISO = 12, and MOSI = 11
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT, SPI_CLOCK_DIVIDER);
#define WLAN_SSID       "X"
#define WLAN_PASS       "Y"
// Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define WLAN_SECURITY   WLAN_SEC_WPA2
Adafruit_CC3000_Client client;
char val2[4];
int pot = 5;
int val;
// We're going to set our broker IP and union it to something we can use
union ArrayToIp {
  byte array[4];
  uint32_t ip;
ArrayToIp server = { 21,74,72,212 };
cc3000_PubSubClient mqttclient(server.ip, 1883, callback, client, cc3000);
void callback (char* topic, byte* payload, unsigned int length) {
  // I have not tested this at all
  // I've gotten the publish up and running
  // use at own risk
void setup(void)
  Serial.println(F("Hello, CC3000!\n"));
  // If you want to set the aref to something other than 5v
  analogReference(EXTERNAL);
  displayDriverMode();
  Serial.println(F("\nInitialising the CC3000 ..."));
  if (!cc3000.begin()) {
    Serial.println(F("Unable to initialise the CC3000! Check your wiring?"));
    for(;;);
  uint16_t firmware = checkFirmwareVersion();
  if ((firmware != 0x113) && (firmware != 0x118)) {
    Serial.println(F("Wrong firmware version!"));
    for(;;);
  displayMACAddress();
  Serial.println(F("\nDeleting old connection profiles"));
  if (!cc3000.deleteProfiles()) {
    Serial.println(F("Failed!"));
    while(1);
  /* Attempt to connect to an access point */
  char *ssid = WLAN_SSID;             /* Max 32 chars */
  Serial.print(F("\nAttempting to connect to ")); Serial.println(ssid);
  /* NOTE: Secure connections are not available in 'Tiny' mode! */
  if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
    while(1);
  Serial.println(F("Connected!"));
  /* Wait for DHCP to complete */
  Serial.println(F("Request DHCP"));
  while (!cc3000.checkDHCP()) {
    delay(100); // ToDo: Insert a DHCP timeout!
  /* Display the IP address DNS, Gateway, etc. */
  while (!displayConnectionDetails()) {
   // connect to the broker
   if (!client.connected()) {
     client = cc3000.connectTCP(server.ip, 1883);
     Serial.println("Broker found");
   // did that last thing work? sweet, let's do something
   if(client.connected()) {
    if (mqttclient.connect("ArduinoUnoClient-CC3000-A4")) {
      mqttclient.publish("sensors/a4/out/debug","A4 is now online");
void loop(void) {
  val = analogRead(pot); // read the pot's analog pin, store it in val
Serial.println(val);
itoa(val,val2,4);
Serial.println(val2); // print the value of val
  // are we still connected?
       if (mqttclient.connect("ArduinoUnoClient-Office-A4")) {
          mqttclient.publish("sensors/a4/out/debug","A4 is now back online");
    // yep, publish that test
    mqttclient.publish("sensors/a4/out", val2);
  Serial.println("pub");
    @brief  Displays the driver mode (tiny of normal), and the buffer
            size if tiny mode is not being used
    @note   The buffer size and driver mode are defined in cc3000_common.h
void displayDriverMode(void)
  #ifdef CC3000_TINY_DRIVER
    Serial.println(F("CC3000 is configure in 'Tiny' mode"));
  #else
    Serial.print(F("RX Buffer : "));
    Serial.print(CC3000_RX_BUFFER_SIZE);
    Serial.println(F(" bytes"));
    Serial.print(F("TX Buffer : "));
    Serial.print(CC3000_TX_BUFFER_SIZE);
  #endif
    @brief  Tries to read the CC3000's internal firmware patch ID
uint16_t checkFirmwareVersion(void)
  uint8_t major, minor;
  uint16_t version;
#ifndef CC3000_TINY_DRIVER
  if(!cc3000.getFirmwareVersion(&major, &minor))
    Serial.println(F("Unable to retrieve the firmware version!\r\n"));
    version = 0;
    Serial.print(F("Firmware V. : "));
    Serial.print(major); Serial.print(F(".")); Serial.println(minor);
    version = major; version <<= 8; version |= minor;
#endif
  return version;
    @brief  Tries to read the 6-byte MAC address of the CC3000 module
void displayMACAddress(void)
  uint8_t macAddress[6];
  if(!cc3000.getMacAddress(macAddress))
    Serial.println(F("Unable to retrieve MAC Address!\r\n"));
    Serial.print(F("MAC Address : "));
    cc3000.printHex((byte*)&macAddress, 6);
    @brief  Tries to read the IP address and other connection details
bool displayConnectionDetails(void)
  uint32_t ipAddress, netmask, gateway, dhcpserv, dnsserv;
  if(!cc3000.getIPAddress(&ipAddress, &netmask, &gateway, &dhcpserv, &dnsserv))
    Serial.println(F("Unable to retrieve the IP Address!\r\n"));
    return false;
    Serial.print(F("\nIP Addr: ")); cc3000.printIPdotsRev(ipAddress);
    Serial.print(F("\nNetmask: ")); cc3000.printIPdotsRev(netmask);
    Serial.print(F("\nGateway: ")); cc3000.printIPdotsRev(gateway);
    Serial.print(F("\nDHCPsrv: ")); cc3000.printIPdotsRev(dhcpserv);
    Serial.print(F("\nDNSserv: ")); cc3000.printIPdotsRev(dnsserv);
    return true;
itoa(val,val2,4);
Why would you want the value converted to a string in base 4? In base 4 a value as large as 1023 will require a lot more than the 4 characters you've allowed for. Even in base 10, you need a minimum of 5 elements in the array, to allow for the terminating NULL.
