potentiometer and servo, jitters at max value
Hey everyone so i am moving two servos with a potentiometer and everything is great no jitter except when i max out the potentiometer in one direction. So say i max out my potentiometer at 90 degrees which is fine for the servo, if i hold it there then it shakes. but if i hold it in the opposite direction and make it go to 0 degrees it doesn't shake. Any ideas on how to stop this? Heres my code. Very simple.
#include <Servo.h>
Servo servo1;
Servo servo2;
int Xin= A0; // X Input Pin
int Yin = A1; // Y Input Pin
int KEYin = 3; // Push Button
void setup ()
pinMode (KEYin, INPUT);
Serial.begin (9600);
servo1.attach(2);
servo2.attach(3);
void loop ()
int xVal, yVal, buttonVal;
xVal = analogRead (Xin);
xVal = map(xVal, 0, 1023, 0, 90); // scale it to use it with the servo
yVal = analogRead (Yin);
yVal = map(yVal, 0, 1023, 0, 90); // scale it to use it with the servo
buttonVal = digitalRead (KEYin);
Serial.print("X = ");
servo1.write(xVal);
Serial.println (xVal, DEC);
Serial.print ("Y = ");
servo2.write(yVal);
Serial.println (yVal, DEC);
delay (5);
What's the output of the serial line if the Servo "shakes", how much movement do you register?
Sounds like a bad pot, intermittent at the end of travel, run this mod and see what the ADC values look like.
#include <Servo.h>
Servo servo1;
Servo servo2;
void setup ()
  servo1.attach(2);
  servo2.attach(3);
void loop ()
  servo1.write(xVal);
  Serial.print(xVal, DEC);
  Serial.print("\t");
  Serial.println(analogRead(Xin));
  servo2.write(yVal);
  Serial.print("\t");
  Serial.println(analogRead(Yin));
  delay (500);
The output i get from the serial monitor says just 0. Doesn't change much at all very stable. It shakes when it is at 0, but it i move the pot the other way to 90 it is completely fine, no shaking and it is a stable 90. If its on a flat surface and i move it to 0 then it shakes as much as moving itself across the surface.
outsider: When i run your code i get this for when i push th pot to 0.
483
0
X = 0
Y = 42
and i get this for when its at 90:
485
1023
X = 90
Y = 42
