Potentiometer size.
Hello everybody I'm very new to the arduino.
I've been wondering; When I connect a potentiometer to an analog input of my arduino, does it make any difference what size (as in ohms) I use? AFAIK the arduino will always read values in the range 0-1023, no matter the size of the potentiometer.
ps: I've been searching the forum before.
You can use any size as it simply splits the voltage.
However, if you use a very small one you will draw lots of current, if you use a very large on there will be a high impedance on the analogue input and so it will be more likely to pick up noise.
Therefore, like the three bares, use a medium size one anything between 1K and 100K will be fine.
Thanks a lot for clarifying. I have no problem with the whole software part of the arduino, but I am a complete noob when it comes to the whole electronics part. I guess I better try to find me a copy of the getting started with electronics and start reading. :slight_smile:
As Mike says, pots between 1k and 100k will work, but best to use 10k or 20k pots. The datasheet indicates that accuracy will be lost for values higher than 20k.
