Potentiometer to adjust 4 LED's up and down in wave-like pattern
I did up top on my first post in the wokwi link.
Anyway I've got it working really well now. I would like to upload a short video but I tried and the zip file was too big. Anyway I will upload my final iteration of the code as I've made some minor tweaks to get it working so well.
// DEFINE ALL PINS TO COMPONENTS
// LED PINS + BRIGHTNESSES
const int LED_YELLOW_PIN = 5; int YELLOW_BRIGHTNESS = 0;
const int LED_BLUE_PIN = 6; int BLUE_BRIGHTNESS = 0;
const int LED_GREEN_PIN = 9; int GREEN_BRIGHTNESS = 0;
const int LED_RED_PIN = 10; int RED_BRIGHTNESS = 0;
// POT_PIN
#define potValue analogRead(POT_PIN)                // ABSOLUTE CURRENT POT VALUE READ
const int POT_PIN = A0;
// LED brightnes
#define mappedPot map(potValue, 0, 1023, 0, 255)    // DEFINE LED BRIGHTNESS BASED ON ABSOLUTE CURRENT POT VALUE
int POT_INPUT_VALUE = potValue;
int LED_BRIGHTNESS = 0;
int time = 0;
  // ESTABLISH PIN MODES
  pinMode(LED_YELLOW_PIN, OUTPUT);
  pinMode(LED_BLUE_PIN, OUTPUT);
  pinMode(LED_GREEN_PIN, OUTPUT);
  pinMode(LED_RED_PIN, OUTPUT);
  // CREATE TIME-STAMP
  time = millis();
  // READ POTENTIOMETER. MAP IT TO PMW VALUE AND SAVE TO VARIABLE
  // ENABLE SERIAL MONITOR FOR DEBUGGING
// ------ PRINT VALUES TO SCREEN --------
void displayValues() {
  Serial.print("Sensor: ");
  Serial.println(POT_INPUT_VALUE);
  Serial.print("PWM Output: ");
  Serial.println(LED_BRIGHTNESS);
// -------- OUTPUT TO LED'S --------
void outputLED() {
  analogWrite(LED_YELLOW_PIN, LED_BRIGHTNESS);
  analogWrite(LED_RED_PIN, LED_BRIGHTNESS);
  analogWrite(LED_GREEN_PIN, LED_BRIGHTNESS);
  analogWrite(LED_BLUE_PIN, LED_BRIGHTNESS);
//  ------------------- POT VALUE HAS CHANGED. UPDATE LED'S GRADUALLY ONE BY ONE ----------------
  void gradualChange() {
    // LED'S GRADUATE UP
    if (potValue > POT_INPUT_VALUE){
      // FOR LOOP 1 - 4 (LEFT TO RIGHT) LED BRIGHTNESS GRADUALLY INCREASES
      for (int L = 0; L <= 3; L++){
        for(int B = LED_BRIGHTNESS; B <= mappedPot; B+=2){
          if (L == 0){                                    //  : OUTPUTS RED LED ONLY TO CURRENT BRIGHTNESS VALUE
            analogWrite(LED_RED_PIN, B);
          else if (L == 1){                               // 1 : OUTPUTS GREEN LED ONLY TO CURRENT BRIGHTNESS VALUE
            analogWrite(LED_GREEN_PIN, B);
          else if (L == 2){                               // 2 : OUTPUTS BLUE LED ONLY TO CURRENT BRIGHTNESS VALUE
            analogWrite(LED_BLUE_PIN, B);
          else if (L == 3){                               // 3 : OUTPUTS YELLOW LED ONLY TO CURRENT BRIGHTNESS VALUE
            analogWrite(LED_YELLOW_PIN, B);
          delay(2);
    else{ // if (potValue < POT_INPUT_PREV_VALUE){
      // FOR LOOP 3 - 0 (RIGHT TO LEFT) LED BRIGHTNESS GRADUALLY DECREASES
      for (int L = 3; L >= 0; L--){
        for(int B = LED_BRIGHTNESS; B >= mappedPot; B-=2){
          delay(2);
// =======================================  MAIN LOOP  ===============================================
  time = millis();                                                // TIME STAMP FOR ALLOWING USER ADJUSTMENT TIME
  // CHECK FOR POT CHANGES WITHIN TIME LIMIT TO ALLOW USER TIME TO ADJUST FURTHER
  while(abs(potValue - POT_INPUT_VALUE) > 5 && millis() - time < 150){
  // IF POT VALUE HAS CHANGED AT 10 CALL gradualChange()
  if(abs(potValue - POT_INPUT_VALUE) > 15){
    gradualChange();
  // UPDATE POT VALUE
  //displayValues();                                               // DEBUGGING
  LED_BRIGHTNESS = mappedPot;                                      // UPDATE LED BRIGHTNESS VALUES TO CURRENT POT VALUE
  outputLED();
  delay(20);
Consider
byte PinLeds [] = { Red, Blue, Green };
Just curious. Why use byte instead of integer?
Memory saving.
A byte stores an 8-bit unsigned number, from 0 to 255. An int stores a 16-bit (2-byte) value on the UNO and other ATmega based boards.
Sweet thanks for the info. I was figuring it was to save memory space but i just didn't understand how it would. Now i do
Another benefit of using a byte on the UNO and ATmega based boards is that they process data in byte-sized chunks, so reading or writing a 2-byte int takes twice as long. Also there are certain circumstances where the other bytes in a multi-byte value can change while you are working with one of the bytes. Keeping the storage as small as possible is best practice.
