Potentiometer with stop points?
What are the knobs called that have stopping points?
Like the source select knob on this amp: http://www.cambridgeaudio.com/media/20081014_152141_a1.jpg.
I presume they’re potentiometers rather than a switch?
sometimes its just the end of a wire spring hitting a flat spot or bump on the shaft
could be a rotary encoder, its probably a switch though
I have a load of pots like that where they have a number of stopping places but I also have some rotary switches which are (as Osgeld described), just a number of switches stuck inside a rotating thing (no need for analog reads - they can control different things on each position).
Rotary encoders generally have no stopping point, they just keep going round and round. I have one which has 8 positions which I am going to use for a menu scroller but I could, just as easily, have 8 different options and a labelled front panel to say what each position was.
Mowcius
Thanks. Do they have a special name?
I rubbish with online electronics shops and end up totally confused by all the things that're returned when I search.
Umm, dunno.
Multi position rotary switch? Not sure...
Mowcius
I've just got back from Maplin.
I wanted a rotary switch. :)
Oh good. I thought that's what they are called.
Mowcius
While you can get rotary switches these tend to be very clunky and require a lot of force, like this one:- http://uk.farnell.com/jsp/search/browse.jsp?N=500006+1000190&Ntk=gensearch_001&Ntt=wafer+switch&Ntx=mode+matchallpartial
Where as you can get rotary encoders with click stops like this:- http://www.potentiometers.com/alpsencoder.cfm The clicks type are known as 'dents' short for indentations. These tend to have a very nice feel.
The clicks type are known as ‘dents’ short for indentations. These tend to have a very nice feel.
Actually, they are known as “detents”:
Call them what you want…
:sunglasses:
Thanks both. Those with the dents do look much better, but as this is my first boxing up of a project I don't need a perfect finish.
I couldn't find the right sized bolts to mount the lcd, and I've no idea how I'll make a bezel. But at least I know what to look for next time :)
I couldn't find the right sized bolts to mount the lcd, and I've no idea how I'll make a bezel. But at least I know what to look for next time.
If it's a standard 20x4 or 16x2 then they are often M2.5s. I often use M2s though because the head is slightly smaller and for that reason, slightly more discrete.
Well that is normally governed my what knobs you stick on them. I have seen a load of nice ones of them...
If you are looking for a bezel then that is what I do! take a look at http://www.duinoaday.wordpress.com for an idea of a few things I have cut. I can do pretty much anything out of acrylic. With etched labels etc if required.
Mowcius
3mm was the smallest B&Q had (or at least that I saw). Ta for the info, at least I know what to look for now.
I had a look at your site the other day. I’m not exaclty sure what I want at the moment. Do you do custom stuff then?
I had a look at your site the other day. I'm not exaclty sure what I want at the moment. Do you do custom stuff then?
I can do custom stuff but not commercially so I do not advertise that fact. PM me if you're interested. Fellow arduino users are on my list of people I will do custom work for though ;)
Sorry for the lack of info on my 'proper site' as to what I can do (the store page still being down and all). It is getting there slowly.
