Potentiometers, rotary encoder and HDD motor to midi
Hello everyone.
I'm a mechanical engineering from Greece and im really new to all this. I have small experience with coding and i would like your help.
I'm trying to build a Midi Controller for DAW (Cubase).
The functions I want to use will consist of:
  • 2 potentiometers (1 linear 500K and 1 slide 10K)
  • 1 rotary encoder
  • 6 to 8 push buttons
  • 1 HDD motor
I'm using a chinese arduino nano (ATmega168) and those softwares:
  • Loopbe1
  • Hairless MIDI
So far i have managed to operate and function with the potentiometers code and the rotary encoder code but as individual codes (Loopbe1 -> Hairless MIDI -> Mapping Cubase -> fully functional).
Also i have managed HDD motor to work but i don't know how to customize the code to "give" Midi outs to be able to work with Loopbe1 and Hairless MIDI.
I have not yet dealt with the push buttons although from a little research I have done it seems to be an easier case.
The help i need is to customise the HDD motor code so it can "communicate" with midi.
Also, as i told at first place, i'm a newbie. How do we merge all codes into one?
Last but not least, can you advise me for an easy to customise push button code for midi operation?
potentiometers code:
[int v0 = 0;
int v0_ = 0;
int v1 = 0;
int v1_ = 0;
int threshold = 5;
int int_to_midi_ratio = 1024 / 128;
void SendMidiToSerial (unsigned char word0, unsigned char word1, unsigned char word2) {
  Serial.write(word0);
  Serial.write(word1);
  Serial.write(word2);
void setup () {
void loop () {
  v0 = analogRead(0) / int_to_midi_ratio;
  v1 = analogRead(1) / int_to_midi_ratio;
  if (v0 - v0_ >= threshold || v0_ - v0 >= threshold) {
    v0_ = v0;
    SendMidiToSerial(176, 42, v0);
  if (v1 - v1_ >= threshold || v1_ - v1 >= threshold) {
    v1_ = v1;
    SendMidiToSerial(176, 43, v1);
}/code]
Rotary encoder code:
[code]
int pinA = 2;
int pinB = 3;
int pinC = 4;
volatile int previous = 0;
volatile int counter = 0;
  Serial.begin(57600);
  pinMode(pinA, INPUT_PULLUP);
  pinMode(pinB, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(pinA), changed, CHANGE);
  attachInterrupt(digitalPinToInterrupt(pinB), changed, CHANGE);
void changed() {
  int A = digitalRead(pinA);
  int B = digitalRead(pinB);
  int current = (A << 1) | B;
  int combined  = (previous << 2) | current;
  if(combined == 0b0010 ||
     combined == 0b1011 ||
     combined == 0b1101 ||
     combined == 0b0100) {
    counter++;
  if(combined == 0b0001 ||
     combined == 0b0111 ||
     combined == 0b1110 ||
     combined == 0b1000) {
    counter--;
  previous = current;
  if(digitalRead(4)==LOW)
    //Send the message
    SendMidiToSerial(176, 47, pinC);
  if(counter >= 1) {
    SendMidiToSerial(176, 44, pinA);
    counter -= 1;
  } else if(counter <= -1) {
    SendMidiToSerial(176, 45, pinB);
    counter += 1;
HDD motor code:
#define L1  A2
#define L2  A3
#define L3  A4
int CW = 0;
int CCW = 0;
boolean L1Val = 0;
const unsigned char PS_128 = (1 << ADPS2) | (1 << ADPS1) | (1 << ADPS0);
  ADCSRA &= ~PS_128;
  ADCSRA |= (1 << ADPS1) | (1 << ADPS0);
  analogReference(INTERNAL);
  pinMode(L1, INPUT);
  pinMode(L2, INPUT);
  pinMode(L3, INPUT);
   if ((analogRead(L1) > 80) && (L1Val == 0)) {
    L1Val = 1;
  if ((L1Val == 1) && (analogRead(L2) > 60)) {
    CW = L2 + 10;
    Serial.println(CW);
    L1Val = 0;
    delay(10);
  if ((L1Val == 1) && (analogRead(L3) > 60)) {
    CCW = L3 - 10;
    Serial.println(CCW);
    L1Val = 0;
    delay(10);
Also a small demonstration:
Thank you
500k is a large value for analogRead, I'd suggest adding a 100nF capacitor to ground to its
wiper to reduce the impedance seen by the ADC.
