Potentiometers works only maximum and minimum
Everything was ok, i was playing game using 2 potentiometers ( like throttel ) and in one time the stop working correct. The are working now on maximum and minimum power only. I wasnt changing anythink in code and in game. I also checked the cables. I dont know what is wrong.
How are you reading the pots ?
Which Arduino pins and which function ?
Please follow the advice on posting code in Read this before posting a programming question
In particular note the advice to Auto format code in the IDE and using code tags when posting code here
 // CONFIG
#define MAX_SWITCHES 13 // the number of switches
byte switch_pin[MAX_SWITCHES] = {2,3,4,5,6,7,8,9,10,11,12,14,15}; // digital input pins
#define DEBOUNCE_TIME 5 // ms delay before the push button changes state
#define MAX_ANALOG 4 // the number of analog inputs
byte analog_pin[MAX_ANALOG] = {A0,A1,A2,A3}; // analog input pins X,Y,Z,THROT
#define ENC_CLK_PIN A4 // rotary encoder CLK input
#define ENC_DAT_PIN A5 // rotary encoder DATA input
#define ENC_MAX 127 // max value of the rotary encoder
#define ENC_MIN -127 // min value of the rotary encoder
#define ENC_ZERO 0 // value to jump to after pressing encoder switch
// END CONFIG
// DECLARATIONS
#include "Joystick.h"
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,JOYSTICK_TYPE_JOYSTICK, MAX_SWITCHES, 0, true, true, true, false, false, false, true, true, false, false, false);
byte reading, clk, clk_old;
byte switch_state[MAX_SWITCHES];
byte switch_state_old[MAX_SWITCHES];
int analog_value[MAX_ANALOG+1]; // +1 for the rotary encoder value
unsigned long debounce_time[MAX_SWITCHES+1]; // +1 for CLK of rotary encoder
// END DECLARATIONS
// FUNCTIONS
int read_rotary_encoder() {
  clk = digitalRead(ENC_CLK_PIN);
  if (clk == clk_old) debounce_time[MAX_SWITCHES] = millis() + (unsigned long)DEBOUNCE_TIME;
  else if (millis() > debounce_time[MAX_SWITCHES]) { // clk has changed and is stable long enough
    clk_old = clk;
		if (clk) {if (digitalRead(ENC_DAT_PIN)) return 1; else return -1;}
  return 0;
// END FUNCTIONS
// SETUP
	for (byte i=0; i<MAX_SWITCHES; i++) pinMode(switch_pin[i],INPUT_PULLUP);
	pinMode(ENC_CLK_PIN,INPUT_PULLUP);
	pinMode(ENC_DAT_PIN,INPUT_PULLUP);
	pinMode(13,OUTPUT); // on board LED
	digitalWrite(13,0);
	Joystick.begin(false);
	Joystick.setXAxisRange(-511, 511);
	Joystick.setYAxisRange(-511, 511);
	Joystick.setZAxisRange(-511, 511);
	Joystick.setRudderRange(ENC_MIN, ENC_MAX);
	Joystick.setThrottleRange(0, 1023);
} // END SETUP
// LOOP
	for (byte i=0; i<MAX_SWITCHES; i++) { // read the switches
    reading = !digitalRead(switch_pin[i]);
    if (reading == switch_state[i]) debounce_time[i] = millis() + (unsigned long)DEBOUNCE_TIME;
    else if (millis() > debounce_time[i]) switch_state[i] = reading;
		if (switch_state[i] != switch_state_old[i]) { // debounced button has changed state
			// this code is executed once after change of state
			digitalWrite(13,switch_state[i]);
			if (switch_state[i]) Joystick.pressButton(i); else Joystick.releaseButton(i);
			if (i==10) analog_value[4] = ENC_ZERO;
			switch_state_old[i] = switch_state[i]; // store new state such that the above gets done only once
	} //END read the switches
	for (byte i=0; i<MAX_ANALOG; i++) { // read analog inputs
		analog_value[i] = analogRead(analog_pin[i]);
		if (analog_value[i] < 256) analog_value[i] = analog_value[i] * 1.5;
		else if (analog_value[i] < 768) analog_value[i] = 256 + analog_value[i] / 2;
		else analog_value[i] = 640 + (analog_value[i] - 768) * 1.5;
		switch(i) {
			case 0:
				Joystick.setXAxis(511 - analog_value[0]);
			case 1:
				Joystick.setYAxis(511 - analog_value[1]);
			case 2:
				Joystick.setZAxis(511 - analog_value[2]);
			case 3:
				Joystick.setThrottle(analog_value[3]);
	analog_value[4] = analog_value[4] + read_rotary_encoder();
	Joystick.setRudder(analog_value[4]);
	// use 2 switches simultaneously to quickly calibrate the rotary encoder
	if (!digitalRead(switch_pin[9]) && !digitalRead(switch_pin[10])) analog_value[4] = ENC_MAX;
	if (!digitalRead(switch_pin[8]) && !digitalRead(switch_pin[10])) analog_value[4] = ENC_MIN;
	Joystick.sendState();
	delay(10);
} // END LOOP
my problem is with zaxis and throttle :o
my connection looks like the picture
Which Arduino? On UNO, Nano, Pro Mini, pins 14 and 15 are A0 and A1.
Pro micro
I'm guessing the pot isn't the problem... Have you tried the [u]Analog Read Serial Example[/u]?
hatiz:
Pro micro
And as your picture is clearly not a pro micro but a Uno you have been misleading us.
One possible explanation is that your pot track is physically broken and the wiper will only connect to one end or the other, giving the symptoms you describe. Find the point where this switch over happens and that is where inside the pot the track is broken.
