Potentiometers
I'm currently working on a project where I use a potentiometer as a dial to turn on different sets of LEDs. My problem is i don't know which potentiometer to get. Would the ohm rating of a potentiometer matter at all when using it like this? Are there other factors to take into consideration? The project book i have doesn't really go far in depth about the hardware side of things.
10k lineair is a common value. It sometimes has 10kB printed on the case. Leo..
I've never seen that.
I have some 10k pots like below and they seem to be a good general match for the arduino.
http://www.ebay.com/itm/10x-B10K-Ohm-Linear-Taper-Rotary-Potentiometer-Panel-Pot-15mm-Shaft-Nuts-Washers-/291010300828?hash=item43c190cb9c:g:BEUAAMXQWzNSeSs6
AWOL:
I’ve never seen that.
Please correct me if I’m wrong.
AFAIK A stands for log (Audio taper), B for lineair, and C for reverse log.
10kB or B10k is 10k lineair.
Leo…
Wawa: Please correct me if I'm wrong. AFAIK A stands for log (Audio taper), B for lineair, and C for reverse log. 10kB or B10k is 10k lineair. Leo..
Hi.
You are correct, old code vs new code.
Taper Old Code New Code Alternate Linear A B LIN Log (Audio) C A LOG Antilog F N/A N/A
