potVal not defined aswell as other parts of code looking invalid
im new to Arduino and think this is awesome stuff thanks in advance for the help. here I have a code copied from DFrobot workshop for their me arm project. it appears no codes are free! when I compile the code I get potVal does not name a type. ive been looking and reading to the point that now im just more confused I know its easy but im still stuck. I think 'potval(0 , 1023) needs to be up in the declarations area? also there are other terms in the loop that I think are going to be a similar issue with other codes in the loop section. I hope someone can clear this up.
  Basic Robot Arm Controller
  robot-arm-control-basic.ino
  Controls 5 DOF Robot Arm, uses Arduino Nano and PCA9685 PWM Controller
  Uses Adafruit PWM library
  Uses 5 potentiometers for input (can be modified for 6)
  DroneBot Workshop 2018
  https://dronebotworkshop.com
// Include Wire Library for I2C Communications
#include <Wire.h>
// Include Adafruit PWM Library
#include <Adafruit_PWMServoDriver.h>
#define MIN_PULSE_WIDTH       650
#define MAX_PULSE_WIDTH       2350
#define FREQUENCY             50
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
// Define Potentiometer Inputs
int controlBase = A0;
int controlElbow = A1;
int controlWrist = A2;
int controlPivot = A3;
int controlJaws = A6;
// Define Motor Outputs on PCA9685 board
int motorBase = 0;
int motorElbow = 1;
int motorWrist = 2;
int motorPivot = 3;
int motorJaws = 4;
// Define Motor position variables
int mtrDegreeBase;
int mtrDegreeElbow;
int mtrDegreeWrist;
int mtrDegreePivot;
int mtrDegreeJaws;
  // Setup PWM Controller object
  pwm.begin();
  pwm.setPWMFreq(FREQUENCY);
// Function to move motor to specific position
void moveMotorDeg(int moveDegree, int motorOut)
  int pulse_wide, pulse_width;
  // Convert to pulse width
  pulse_wide = map(moveDegree, 0, 180, MIN_PULSE_WIDTH, MAX_PULSE_WIDTH);
  pulse_width = int(float(pulse_wide) / 1000000 * FREQUENCY * 4096);
  //Control Motor
  pwm.setPWM(motorOut, 0, pulse_width);
// Function to convert potentiometer position into servo angle
int getDegree(int controlIn);
  int potVal,srvDegree;
  // Read values from potentiometer
    potVal = analogRead(controlIn);
  // Calculate angle in degrees
  srvDegree = map(potVal,  0, 1023, 0, 180);
  // Return angle in degrees
  return srvDegree;
  //Control Base Motor
  // Get desired position
  mtrDegreeBase = getDegree(controlBase);
  // Move motor
  moveMotorDeg(mtrDegreeBase,motorBase);
  //Control Elbow Motor
  mtrDegreeElbow = getDegree(controlElbow);
  // Move motor
  moveMotorDeg(mtrDegreeElbow,motorElbow);
  //Control Wrist Motor
  mtrDegreeWrist = getDegree(controlWrist);
  // Move motor
  moveMotorDeg(mtrDegreeWrist,motorWrist);
  //Control Pivot Motor
  mtrDegreePivot = getDegree(controlPivot);
  // Move motor
  moveMotorDeg(mtrDegreePivot,motorPivot);
  //Control Jaws Motor
  mtrDegreeJaws = getDegree(controlJaws);
  // Move motor
  moveMotorDeg(mtrDegreeJaws,motorJaws);
  // Add short delay
  delay(20);
thank you im sleepy and burned out so I apologize for any descrepencies. I had to use a forum to use this forum! and also id like to hear another description of how the syntax is ordered.
Only one tiny problem:
should be
Then it compiles.
I don't know exactly where you got that code but it was correct in several sites I looked at.
Steve
