Hi Guys,
So, I've gone through the instructable for building a POV HDD Clock, and I'm having a problem I hope one of you can help me with.
Here is a link to the Instructable. Maybe the author of this instructable is on this forum?
http://www.instructables.com/id/Hard_Drive_Persistence_of_Vision_HDPOV/
If you look through the instructable, the code can be found at the end.
The only thing I did differently from the author was I used an optical interrupt package rather than building one out of discreet components like the one detailed in his instructable. Here is the interrupt I used:
I looked at the output of the optical interrupt on my o'scope, and the output is reading the speed of the Hard drive correctly, and is outputting 5V on every revolution. I can upload a couple of screenshots of the scope readings when I get home if you guys think it will help.
I have also verified that the LED strip is working by putting 12V across each of the signal lines and the common line and it works.
I suspect that the sketch provided was taylored specifically for the discreet component interrupt switch solution that the author designed, and that the sketch needs to be changed in some way to understand the optical interrupt package I used. I have looked at the sketch so many times that I'm running around in circles in my head and can't seem to isolate what might need to be changed to get the system to work.
Specifically, the problem I'm having is that the LED strip will not light up when it is placed in the system, but it will light up when I power it up directly with 12V.
Any help anyone can offer would be greatly appreciated. I can provide more details too when I get home and look over my notes.
