POV LED-ARDUINO UNO-HELP
hello, I’m trying to make a POV (Persistence Of Vision), for my bike, I’m painting a circle, and works well with constant speeds.
the problem is that when the velocity is decreasing, or stopped pedaling
the circle is not closed, is there any way to solve this?
thank you!
volatile unsigned long timeold;
volatile unsigned long new_time = 0;
volatile unsigned long refreshEnd = 0;
volatile  unsigned long Refresh = 0;
volatile unsigned long milliperrevolution = 0;
volatile unsigned long revolutions=0;
volatile boolean interruptHit = false;
 pinMode(2, INPUT); //
  attachInterrupt(0, rpm, FALLING);//    attachInterrupt(0, rpm, FALLING) pin 2 Arduino----     : hall sensor
 pinMode(13, OUTPUT);
 digitalWrite(13, 0);   // set the LED off
int c=0;
  if( interruptHit ==true){
                   interruptHit =false;
      digitalWrite(13, HIGH);   // set the LED
    new_time = millis();
    refreshEnd=new_time;
    while((millis() - refreshEnd)<= (Refresh  ) ) {;}
  }else{
        digitalWrite(13, LOW);   // set the LED
void rpm(){
 revolutions++;
 interruptHit=true;
 if (revolutions == 2)                                     // RPM gets updated for every two complete rotations
     new_time=millis();
      milliperrevolution = (( new_time - timeold)/2);
      timeold =  new_time;
     revolutions = 0;
      Refresh = milliperrevolution/1;  //number the  slice
Averaging duration two revolutions will only help if the speed is constant. If you are speeding up the average duration will be too high and if you are slowing down the average duration will be too low. Try using just one revolution and using microseconds for measurement to get more accuracy.
volatile unsigned long microsecondsPerRevolution = 0;
  attachInterrupt(0, rpm, FALLING);  // hall sensor
  digitalWrite(13, LOW);   // set the LED off
  static unsigned long start_time;
  if (interruptHit) {
    digitalWrite(13, HIGH);   // LED on
    start_time = micros();
  unsigned long mpr;
  // Copy the microsecondsPerRevolution value with interrupts disabled, otherwise we might be
  // half way through copying the value and the ISR will change it!
  noInterrupts();
  mpr = microsecondsPerRevolution;
  interrupts();
  if(micros() - start_time > mpr)
    digitalWrite(13, LOW);   // LED off
void rpm() {
  static unsigned long old_time;
  unsigned long new_time = micros();
  microsecondsPerRevolution = new_time - old_time;
  interruptHit = true;
  old_time =  new_time;
johnwasser: Averaging duration two revolutions will only help if the speed is constant. If you are speeding up the average duration will be too high and if you are slowing down the average duration will be too low. Try using just one revolution and using microseconds for measurement to get more accuracy.
void setup() {  pinMode(2, INPUT); //  attachInterrupt(0, rpm, FALLING);  // hall sensor
 pinMode(13, OUTPUT);      digitalWrite(13, LOW);   // set the LED off }
void loop() {  static unsigned long start_time;
 if (interruptHit) {    digitalWrite(13, HIGH);   // LED on    start_time = micros();    interruptHit = false;  }
 unsigned long mpr;
 // Copy the microsecondsPerRevolution value with interrupts disabled, otherwise we might be  // half way through copying the value and the ISR will change it!  noInterrupts();  mpr = microsecondsPerRevolution;  interrupts();
 if(micros() - start_time > mpr)    digitalWrite(13, LOW);   // LED off }
void rpm() {  static unsigned long old_time;  unsigned long new_time = micros();
 interruptHit = true;  old_time =  new_time; }
hello, thanks for your help ........... but the problem remains the same =( I tried to take a picture but I have 4 hands-
You can't use the time of the previous revolution as the length of the current revolution if the speed is changing. You might get closer if you track the difference between the last two revolutions and add that to the previous revolution:
  if (interruptHit) {
  unsigned long mpr;
  noInterrupts();
  interrupts();
void rpm() {
  static unsigned long lastMPR = microsecondsPerRevolution;
  long deltaMPR = microsecondsPerRevolution - lastMPR;
  // Adjust the current microsecond count to better anticipate the
  // time for the NEXT revolution.
  microsecondsPerRevolution += deltaMPR;
johnwasser:
You can’t use the time of the previous revolution as the length of the current revolution if the speed is changing. You might get closer if you track the difference between the last two revolutions and add that to the previous revolution:
if (interruptHit) {
unsigned long mpr;
  noInterrupts();
  interrupts();
void rpm() {
hello, I have bad news, does not work.
This exceeded the time code, ie removing an time for two laps, because if I divide by 2. mpr = (microsecondsPerRevolution / 2);
should only paint half a circle, and it is not, paints almost full circle, I mean is the same effect, an open circle.
johnwasser greetings, sorry for the inconvenience.
any ideas?
any ideas?
Just the obvious ones - post your current code and a description of the (current) problem(s).
PaulS:
any ideas?
obvious what is already published
Add a gyro and know the speed 100 to 1000x a second.
GoForSmoke: Add a gyro and know the speed 100 to 1000x a second.
Add a gyro and know the speed 100 to 1000x to second.
LOl, as I do that?, I have a gyroscope out of a WII
Solid state gyro modules weigh far less and have much lower power requirements. An accelerometer turning in the vertical will be affected by gravity but a gyro may give only angular change which on a turning bicycle wheel can translate directly to movement speed.
Imagine trying to put your ancient gyro into a cellphone or tablet where the solid state gyro goes mostly unnoticed?
http://www.ebay.com/itm/MPU-6050-Triple-Axis-Accelerometer-Gyro-Breakout-Module-/251132720300?pt=LH_DefaultDomain_0&hash=item3a78ad34ac
Be sure to check the buy more and save prices, 3 for $10.04 ea, etc, does add to shipping. http://dx.com/p/gy-50-l3g4200d-3-axis-digital-gyro-sensor-module-for-arduino-148731
I have bought direct from factory here and gotten lower prices but since I asked them and got a quote that is the price I get (less than $10) and you have to ask for your own. Caveat, there is a small, probably subsidized, shipping charge so I don't order just one thing at a time. So far my only problem module from there has been the VS1053 MP3 module that came set up for voice recognition. Badji here was able to do the fix, a credit to his soldering skill. I have not tackled the gyro-accelerometer yet as wrapping up an MP3 module has consumed most of my gumption (frustration will do that, especially in old people) for quite a while.
GoForSmoke:
I have bought direct from factory here and gotten lower prices but since I asked them and got a quote that is the price I get (less than $10) and you have to ask for your own. Caveat, there is a small, probably subsidized, shipping charge so I don’t order just one thing at a time.
as what you could adapt meciona to my project?
Your avr and leds are to be held on the spokes? A gyro with them should tell the rate of turn.
It will be a project in itself to get that working but the capability is there.
You could put a magnet on a frame stay or fork (the parts that hold the wheels) and a Hall sensor or reed switch to read that but then you only have data from a full turn of the wheel which is only good at constant speed. The gyro should read fast enough for many times in a turn of the wheel.
Sorry but I am only good with English and was never more than a beginner en Francais. I think that meciona is Italian for something to do with machines but that is just a guess. If you had written machina then I would guess Spanish but with either language I am useless.
GoForSmoke: Your avr and leds are to be held on the spokes? A gyro with them should tell the rate of turn.
I want to draw a circle, but this is always open. after this time will be used to divide into smaller parts, to draw something more complex
i speak spanish.
I've seen numbers Povisa project bike, which only uses the hall sensor for constant and variable speeds. what he says can be a bit tricky to implement my project gyroscope.
someone who helps to make the time for variable speeds.
  if (interruptHit) {
  unsigned long mpr;
  noInterrupts();
  interrupts();
void rpm() {
How many "slices" of your image are you trying to display per revolution? As in how many times are you turning on and off your LED's per revolution? I have a suggestion. Calculate how long the last revolution took, in microseconds.
Each revolution: An interrupt will be triggered. When your interrupt triggers calculate how long it took for the previous revolution. Divide the time it took for the previous revolution by the number of "slices" you are trying to display. This will be your delay time in between slices. Almost done. You also need to know how long it takes for your processor and LED drivers to push the data out and latch per "slice." This will have to be benchmarked on its own. My suggestion is to take your image and have it just push out the entire image with no pausing and time how long it takes for the entire image to cycle through. You dont have to spin the wheel for this, just have it output the time in microseconds to the terminal. I would do at least ten attempts at this and record each time. Divide that time by the number of "slices" and you should have a "decent" knowledge of how long each slice takes to push out to the LEDs and latch. So now you know how long each "slice" will take to display, and how long to pause before displaying the next "slice."
From here it will take some fiddling with to get the timing right, but you should be a closer than you were before. Granted sudden accelerations in either direction will cause the image to rotate a little, but this should at least eliminate the variable gap in the image.
Do you have any drawings of how you are "slicing" up your images? How are you creating the data for the images?
Does that make sense?
RBQAA
All POV displays require fast motion of the leds.
SpokePOV: LED Bike Wheel Images
http://www.instructables.com/id/SpokePOV%3A-LED-Bike-Wheel-Images/
With one spoke, total persistence at 15mph. Two spokes, 10mph. Three spokes, 7mph. (Assuming a mountain bike wheel). Looks cool even if not completely persistant.
They put the lights on more than 1 spoke and still when it gets slow it breaks up.
Open Source POV Bicycle Wheel Animation
http://hacknmod.com/hack/open-source-bicycle-pov-display-pictures-animation/ http://www.instructables.com/id/RGBike-POV-Open-project/
These are the practical ones:
Revolights ensure maximum safety by providing both lighting and sighting in one fully-integrated, revolutionary design.
http://revolights.com/
I have seen examples numbers and codes, and none I've seen where you can predict the time of a turn with a hall sensor, so it always drifts LEDs.
a gyroscope final thoughts about a solution, but for me is very complicated, I guess you should first go through some filter, for example Filter "Kalman" per second to calibrate the sensor as?, No idea. by third timing. by definition the gyroscope measures angular velocity instant, so for our purposes, deberianos not make any transformation, exentrica Math. eg gyro directly thrown Out = 122 IP / Second, here, do not know how to interpret this info to light the LEDs for a full turn.
in short, so far I have been able to achieve a decent picture, the only thing I've won is a headache both see the LEDs. as no. my language is Spanish, I find enteder well without comcreto example, I'll see if I can decibrar what the Lord tells me RGB
This is easy to moderately easy to do, I've done something similar. but then an idea, no matter how sensilla is, what matters is that one there is no prior occurido.
now in its latest version, you incorporated a aceletrometro, so that a certain view is used to measure the braking, which led brightness is inversely proportional to the acceleration.
Greetings, thx for everything, we're seeing.
The Open Source link I posted has source code. You can use that.
With Hall sensor the wheel must revolve complete before the sensor and wheel are back together. If speed changes during then, the code has no way to know. With steady speed it is good, with changing speed not good, with slow speed or stop it is no good.
Perhaps in the code make the leds only shine when speed is fast and steady enough for good display?
Revo light uses 1 led per spoke on many spokes, spokes on both sides of the wheel. And here is a thought, the metal spoke can be used as ground so only 1 wire per led is needed.
