I've been coding around a bit while trying to make a POV.
It's 15 led's wide.
This is my code:
const byte d0[14] = {
B00111111, B1111100,
B01111111, B1111110,
B11000000, B0000011,
B00111111, B1111100
const byte d1[14] = {
B11000000, B0000000,
B11000000, B0001100,
B11000000, B0001110,
B11111111, B1111111,
B11000000, B0000000
const byte d2[14] = {
B11000000, B0111100,
B11100000, B0111110,
B11110000, B0000111,
B11011000, B0000011,
B11001100, B0000111,
B11000111, B1111110,
B11000001, B1111100
const byte d3[14] = {
B00111000, B0011100,
B01111000, B0011110,
B11100000, B0000111,
B11000001, B0000011,
B11100011, B1000111,
B01111110, B1111110,
B00111100, B0111100
const byte d4[14] = {
B00001110, B0000000,
B00001111, B1000000,
B00001100, B1110000,
B00001100, B0011100,
B00001100, B0000000
const byte d5[14] = {
B00111001, B1111111,
B01111001, B1111111,
B11100001, B1000011,
B11000001, B1000011,
B01111111, B1000011,
B00111111, B1000011
const byte d6[14] = {
B11100111, B1000111,
B11000011, B1000011,
B01111110, B0001110,
B00111100, B0011100
const byte d7[14] = {
B00000000, B0000011,
B01111000, B0000011,
B00001111, B0000011,
B00000001, B1111011,
B00000000, B0011111,
B00000000, B0000011
const byte d8[14] = {
B00111100, B0111100,
B00111100, B0111100
const byte d9[14] = {
B00111000, B0111100,
B01110000, B1111110,
B11100011, B1100111,
B00111111, B1111100
const byte dots[14] = {
B00000000, B0000000,
B00001000, B0010000,
B00011100, B0111000,
B00000000, B0000000
byte pins[15] = {
14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1};
byte povlength = 15;
for(int i = 0; i < povlength; i++) {
pinMode(pins[i], OUTPUT);
digit_out(4);
void digit_out(int which) {
switch(which) {
case 0:
out(d0);
case 1:
out(d1);
case 2:
out(d2);
case 3:
out(d3);
case 4:
out(d4);
case 5:
out(d5);
case 6:
out(d6);
case 7:
out(d7);
case 8:
out(d8);
case 9:
out(d9);
void out(const byte *data) {
for (byte x=0; x<14; x+=2) {
column(data[x+1], data[x]);
delayMicroseconds(100);
column(B00000000, B0000000);
void column(byte data, byte data2) {
for (byte y=0; y<8; y++) {
digitalWrite(pins[y], data & (1<<y));
digitalWrite(pins[y+7], data2 & (1<<y));
But it doesn't seems to work! My lights light up very randomly and definitely not as the are supposed to.
But when I remove some statements in the switch-case digit_out function, it does work? So it seams to freak out while using more digits/chars.
I commented out everything above 6 in the code below, if I want to use like say number 7, it starts to freak out.
switch(which) {
case 0:
out(d0);
case 1:
out(d1);
case 2:
out(d2);
case 3:
out(d3);
case 4:
out(d4);
case 5:
out(d5);
case 6:
out(d6);
/*case 7:
out(d7);
case 8:
out(d8);
case 9:
out(d9);
break;*/
What can be the problem?
