Not sure if this should be here or in "programming" but I'll start here.
Like many I'm trying to reduce power for battery operation.
My setup:
Pro Mini Clone with 3.3v regulator in circuit. Power LED disconnected. No I/Os connected to anything. I changed the fuses so the Brownout function is disabled.
Using Nick Gammon's Sketch J on the Pro mini with nothing connected the current is ~ 30 - 33 µA. Nick's website states the current should be in the 1µA area. Now looking at a typical low dropout regulator it seems the quiescent current is in the 50µA area so I think I'm doing pretty well.
Question: Has anyone had similar results? Would like to know if I was really missing something.
The voltage limitation for the RFM69 is not the low end but the high end. If I start with a battery voltage of 4.5 or so I must regulate it down to be below the max RFM69. Hence the regulator.
