Power consumption of I2C bus
Hi everyone,
I have a project of low power camera, using an Arduino pro mini (with watchdogs), a camera, and a RTC timer, both working with SPI bus.
In order to save battery, I use TIP122 transistors to switch of power pins to camera and RTC.
My question is simple : is it enough to limit the power consumption, or do the SDA and SCL draw also current ?
If yes, is there a way to 'completly' disconnect it ? Maybe with BJT transistors ?
Thank you !
If you cut the high side (5 V) power to the I2C bus devices, the bus pull-ups which tie to 5 V, will draw current and “phantom” power the various devices, so you have to disconnect the pull-ups from the 5 V also. An Arduino pin can do this easily.
Thank you very much Paul__B !
My pull up resistors are already in the chipcard (I use DS3231 for RTC, for exemple)
I cut the low side (GND) of my I2C device. Is it a problem for the power consumption ?
SPI or I2C?
Low side switching should be OK. Why do you cut power to the RTC? It defeats the purpose of the (very accurate) RTC.
Smajdalf:
SPI or I2C?
It is I2C.
My RTC module as a small battery for it, I want to cut power from the 5V pin, which is used by LEDs on the chip board and other things. :slight_smile:
Could you please post a schematic of your circuit?
Are you using the TIP122 for a particular reason? It's a Darlington as I remember.
The I2C lines have pullup resistors. On the RTC these resistors pull up to the Vcc header. But if you are switching off the RTC module's ground connection, I don't see how there could be any current flow. There would be no return path. But the test would be to measure the current at the Vcc pin with your meter. I don't know about the camera.
