I want to send some data with Pro Mini and Rf24l01. It needs to work no matter if power is cut off. So, it needs a batteries.
How to set it, so it works from a power supply, but when power switch off, it goes on with batteries. When power gets back, switch to mains again, and charge that battery.
My pick are 18650 batteries with tp4056 module. But what circuit to use to switch source when mains goes off?
Do you know the power draw of your unit?
Do you know the maximum current draw of the unit (when it is doing its work)?
Do you know the idle current (the lowest)?
What is considered the worst case scenario for a brown/power out?
What is the usual power out duration?
What is your circuit doing? Is it polling for data, sleeping and waking after x seconds etc...
Some design changes could even make this a completely mains-less device removing the need for "back-up" almost completely.
For example, a reading an hour can happily be done on even a power capacitor bank + solar panel trickle for basic stuff.
What you need is a <50cent "TP4056 Li-Po Charger protected" - does the charging and protecting battery from overcharge and under discharge voltages. Power an 8Mhz arduino directly from the "load" leads, or a 16Mhz (5V) one with a boost converter.
It's pro mini 3,3V 16MHz which reads temp with NTC a send data via rf24l01 every 30sec.
It needs to operate no matter if power goes down, and there are times it goes down. So it is not necessary do switch immediately, but it needs to switch to battery. When power comes on, switch to power supply and battery starts charging if necessary.
