power issues while hooked up to batteries
So, i've built a small spider robot (not really a spider, it has 4 legs lol). It is run by an arduino Nano (for now) which is connected to a PCA9685 over I2C for easy controll of the 12 MG995 servos. Now all of this is powered by 2, 30C samsung 18650s in series. There is a pretty heavyduty buck-boost converter which delivers 6.0 V for the servos and the arduino nano should pull directly from the li-ions (~8V). When i have the Nano connected to my pc the robot runs fine. It can walk forward without any issuse but as soon as i try too run it off of battery power directly the buck-boost converter starts to blink and the servos give in, as if there wasnt enough current to power them. i feel like this should work just fine but obviously im doing something wrong, any thoughts?
Thank you
MansArildssom:
Thank you
Did you disconnect the USB cable when you ran from batteries?
Paul
Yes, that probably happened a few times.
MansArildssom:
I think you missed the point Paul was making.
I probably did, could you clarify?
MansArildssom:
That seems to be a rather common cause of problems lately. Somewhere there was a rational discussion of what trouble it causes and why. Don't have a link to it right now. But it is a perfect way to kill things!
Paul
