Power limitations?
I was wondering if a arduino mega could power 8 magnetic reed switches and 2 * 5v PIR(HC-SR501) and hook them up to the analog inputs via a voltage divider (5.6k ohm 0.5W & 10k ohm 0.5W) or do I need an external power source to power all of that, if so what would the required circuit look like?
I was wondering if a arduino mega could power 9 magnetic reed switches
A switch consumes no power, so yes.
A PIR sensor consumes very little power, so yes.
The output of a switch, or PIR sensor, powered by the Arduino will be 0 V or 5V, so you don't need any voltage dividers.
PaulS:
The voltage dividers are to detect if there was a short created: 0v if open, ~3v if correctly closed, 5v if shorted.
From what I understand I would connect:
5v power -----> Reed switch 1 ---> Analog 1 (Voltage divider)
|--> Reed switch 2 ---> Analog 2 (Voltage divider)
|--> Reed switch 8 ---> Analog 8 (Voltage divider)
|--> PIR 1 ---> Analog 9 (Voltage divider)
|--> PIR 2 ---> Analog 10 (Voltage divider)
and code would read values from each input
That seems to make little sense. The only way you'll see 5V on a pin is if the voltage divider is shorted out or there is somehow a short direct from 5V to the analog pin. How are you expecting either of those to happen?
Steve
slipstick:
Steve
Tampering via external sources such as a malicious person.
5v ---(long run)-----Reed Switch--5.6kOhm------(long run)-------|---10k ohm
Analog read from here
I could also add a parallel resistor to give me 4 states:
Line Cut: 0v
Line shorted(would avoid the resistors): 5v
Magnetic Reed open: ~2.857v
Magnetic Reed closed: ~3.205v
Edit the resistors are in K Ohms
