Hi all,
I am currently doing a project on Battery management and was tasked to use the Waveshare power Management HAT for this project.
The objective of this project is to create a system that can control the raspberry PI power. Meaning to say controlling it awake time and sleeping time. At the say time I will need the print out of the current every seconds to monitor if there is any lowered power consumption during the different state.
So currently my code goes like this:
#include "PowerManagementHAT.h"
#include "Time.h"
#include "LowPower.h"
#include "PCF8523.h"
#include <Wire.h>
const char *monthName[12] = {
"Jan", "Feb", "Mar", "Apr", "May", "Jun",
"Jul", "Aug", "Sep", "Oct", "Nov", "Dec"
const int USER_LED = 13;
//Timebase set to seconds. Other options: eTB_SECOND, eTB_MINUTE, eTB_HOUR
//eTIMER_TIMEBASE PERIODIC_TIMER_TIMEBASE = eTB_MINUTE;
#define PERIODIC_TIMER_TIMEBASE eTB_SECOND
//The timer interval in unit of PERIODIC_TIMER_TIMEBASE
#define PERIODIC_TIMER_VALUE 120
//RPI stay awake time
#define RPI_STAY_AWAKE_TIME_MS 60000
tmElements_t tm;
void alarm_isr()
//The handle of RTC alarm
// Configure output pin
pinMode(USER_LED, OUTPUT);
// turn off the light
digitalWrite(USER_LED, HIGH);
// initialize serial communication: In Arduino IDE use "Serial Monitor"
Serial.println("Starting, but I'm going to go to sleep for a while...");
Serial.println("Measure the Raspberry Pi Current");
delay(60);
//RTC init with a interrupt
power.RTCInit(true);
//Just set the time(Compiled) to RTC clock.
if (getDate(__DATE__) && getTime(__TIME__)) {
power.setTime(DateTime(F(__DATE__), F(__TIME__)));
piRunCurrent = power.measureCurrent();
Serial.print("The Raspberry Pi running current: ");
Serial.print(piRunCurrent);
Serial.println(" mA");
//print the time in serial monitor
printTimeNow();
Serial.print("Periodic Interval Set for: ");
Serial.print(PERIODIC_TIMER_VALUE);
switch (PERIODIC_TIMER_TIMEBASE)
case eTB_SECOND:
Serial.print(" seconds");
case eTB_MINUTE:
Serial.print(" minutes");
case eTB_HOUR:
Serial.print(" hours");
default:
Serial.print(" unknown timebase");
Serial.print(" + ");
Serial.print(RPI_STAY_AWAKE_TIME_MS / 1000);
Serial.println(" seconds");
bool piRunFlag;
float piRunCurrent;
power.RTCClearInterrupts();
//Allow wake up alarm to trigger interrupt on falling edge.
attachInterrupt(0, alarm_isr, FALLING);
//configue the period
power.setTimer1(PERIODIC_TIMER_TIMEBASE, PERIODIC_TIMER_VALUE);
//when clock is set,then print the register of the RTC
// PrintRTCRegisters();
//Serial print requires time,so delay here
//just like enter the low power mode
//it will wake up util the wakeup pin is low(just like the alert rings)
power.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF);
//Alarm,and then disable the interrupt
detachInterrupt(0);
//Ack the alarm
power.ackTimer1();
//Then wake the Pi
power.connectPiPower(true);
//Turn on the LED
digitalWrite(USER_LED, LOW);
Serial.println("I am waking!!!");
//Print the time
printTimeNow();
//print the time requires time
delay(50);
//This is the stay awake time
delay(RPI_STAY_AWAKE_TIME_MS);
Serial.println("shutting down");
//Has been awaked for a time,then shutdown.
power.shutPiDown();
void printTimeNow()
// Read the time
DateTime now = power.readTime();
// Print out the time
Serial.print("Ok, Time = ");
print2digits(now.hour());
Serial.write(':');
print2digits(now.minute());
Serial.write(':');
print2digits(now.second());
Serial.print(", Date (D/M/Y) = ");
Serial.print(now.day());
Serial.write('/');
Serial.print(now.month());
Serial.write('/');
Serial.print(now.year(), DEC);
return;
bool getTime(const char *str)
int Hour, Min, Sec;
if (sscanf(str, "%d:%d:%d", &Hour, &Min, &Sec) != 3) return false;
tm.Hour = Hour;
tm.Minute = Min;
tm.Second = Sec;
return true;
bool getDate(const char *str)
char Month[12];
int Day, Year;
uint8_t monthIndex;
if (sscanf(str, "%s %d %d", Month, &Day, &Year) != 3) return false;
for (monthIndex = 0; monthIndex < 12; monthIndex++) {
if (strcmp(Month, monthName[monthIndex]) == 0) break;
if (monthIndex >= 12) return false;
tm.Day = Day;
tm.Month = monthIndex + 1;
tm.Year = CalendarYrToTm(Year);
return true;
void print2digits(int number) {
if (number >= 0 && number < 10) {
Serial.write('0');
Serial.print(number);
void PrintRTCRegisters(void)
//This message is just for debug
uint8_t reg_value;
reg_value = power.rtcReadReg(PCF8523_CONTROL_1);
Serial.print("Control 1: 0x");
Serial.println(reg_value, HEX);
reg_value = power.rtcReadReg(PCF8523_CONTROL_2);
Serial.print("Control 2: 0x");
reg_value = power.rtcReadReg(PCF8523_CONTROL_3);
Serial.print("Control 3: 0x");
reg_value = power.rtcReadReg(PCF8523_SECONDS);
Serial.print("Seconds: ");
reg_value = power.rtcReadReg(PCF8523_MINUTES);
Serial.print("Minutes: ");
reg_value = power.rtcReadReg(PCF8523_HOURS);
Serial.print("Hours: ");
reg_value = power.rtcReadReg(PCF8523_DAYS);
Serial.print("Days: ");
reg_value = power.rtcReadReg(PCF8523_WEEKDAYS);
Serial.print("Week Days: ");
reg_value = power.rtcReadReg(PCF8523_MONTHS);
Serial.print("Months: ");
reg_value = power.rtcReadReg(PCF8523_YEARS);
Serial.print("Years: ");
reg_value = power.rtcReadReg(PCF8523_MINUTE_ALARM);
Serial.print("Minute Alarm: ");
reg_value = power.rtcReadReg(PCF8523_HOUR_ALARM);
Serial.print("Hour Alarm: ");
reg_value = power.rtcReadReg(PCF8523_DAY_ALARM);
Serial.print("Day Alarm: ");
reg_value = power.rtcReadReg(PCF8523_WEEKDAY_ALARM);
Serial.print("Weekday Alarm: ");
reg_value = power.rtcReadReg(PCF8523_OFFSET);
Serial.print("Offset: 0x");
reg_value = power.rtcReadReg(PCF8523_TMR_CLKOUT_CTRL);
Serial.print("TMR_CLKOUT_CTRL: 0x");
reg_value = power.rtcReadReg(PCF8523_TMR_A_FREQ_CTRL);
Serial.print("TMR_A_FREQ_CTRL: 0x");
reg_value = power.rtcReadReg(PCF8523_TMR_A_REG);
Serial.print("TMR_A_REG: 0x");
reg_value = power.rtcReadReg(PCF8523_TMR_B_FREQ_CTRL);
Serial.print("TMR_B_FREQ_CTRL: 0x");
reg_value = power.rtcReadReg(PCF8523_TMR_B_REG);
Serial.print("TMR_B_REG: 0x");
I would need some of your expertise to advice me on how can I better make it to function in the way I need it and also learning better about this code.
