hi
I am after making a power meter similar to kendin yap on youtube have not the foggist of how to start programming for this add on when I get the components I want to make the meter but using a tft lcd screen , he used a 0.89 screen so I can add the time ,date as well as amps/watthrs/watts and volts ,I would like to monitor watts and keep a running total of the highest number ,I am linking to wind turbine and want to know the highest wattage the turbine has done and then using hc-05 to send dats by Bluetooth to phone ,I have an idea what I want to do just do not know how to start,first ever project any help / tips the way forward would be good
regards
colin
So, you want to know how to run a marathon before you know how to crawl?
hi
looks like it ,if you gonna go for it just do it, will be a learning curve that's for sure,plenty of reading and trying out different sensors ect
colin
cfinch:
Get an Arduino, learn how to blink LEDs, read switches etc.
How to read voltages of batteries etc.
Get a display, learn how to install the libary for it and write your own messages to the display.
It really is a very good idea to start at the beginning ...........................
hi
got that far already its the rest im struggling with thought id try a project and try and improve it
colin
cfinch:
hi
colin
Well then, you probably need to list the specific parts you are struggling with, and what you have done so far to address the issues. This forum has a search function you might use first to get some background information on the parts of your project.
rephrasing slightly:
you want to do a number of individual things
then combine them
learning how to do individual things is one skill
each individual thing is another skill
combining things is a skill
so learn how to measure amps and volts
learn how to make your display work
combine them
on and on until you get to your goal
