I wrote a code where while pressing 0,1,2,3 and 4 button on the IR adequate number of LEDs are turned on
#include <IRremote.h>
int IRpin=3;
IRrecv irrecv(IRpin);
decode_results results;
int LED1= 6;
int LED2= 8;
int LED3= 10;
int LED4= 12;
void setup(){
irrecv.enableIRIn();
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(LED3, OUTPUT);
pinMode(LED4, OUTPUT);
void loop(){
if (irrecv.decode(&results)){
unsigned long read = results.value;
switch(read)
case 0xFF6897:
//Serial.println("0"); // button 0
digitalWrite(LED1, LOW);
digitalWrite(LED2, LOW);
digitalWrite(LED3, LOW);
digitalWrite(LED4, LOW);
case 0xFF30CF:
//Serial.println("1"); // button 1
digitalWrite(LED1, HIGH);
case 0xFF18E7: // button 2
//Serial.println("2");
digitalWrite(LED2, HIGH);
case 0xFF7A85: // button 3
//Serial.println("3");
digitalWrite(LED3, HIGH);
case 0xFF10EF: // button 4
//Serial.println("4");
digitalWrite(LED4, HIGH);
{ Serial.println(results.value,HEX);
irrecv.resume();
This code is working properly but I have to include that unless button number 8 is pressed the program is not working and if it's pressed again then the whole program stops working and LEDs cannot be turned.( something like in power on/off button in a TV remote). I don't know how to do it because every time I try to include if statement before switch case like below or in another way none of the LED can be turned on. There's probably something missing in that if statement.
int IRpin=3;
int LED1= 6;
int LED2= 8;
int LED3= 10;
int LED4= 12;
void setup(){
void loop(){
if (irrecv.decode(&results) ){
int sensorValue=0;
sensorValue = digitalRead(LED1);
sensorValue = digitalRead(LED2);
sensorValue = digitalRead(LED3);
sensorValue = digitalRead(LED4);
if (read==0xFF4AB5 ){ // if button number 8 is pressed
switch(read)
case 0xFF6897:
{digitalWrite(LED1, LOW);
break;}
case 0xFF30CF:
{digitalWrite(LED1, HIGH);
break;}
case 0xFF18E7:
break;}
case 0xFF7A85:
case 0xFF10EF:
irrecv.resume();
