I am a newie in this area and I really need your help if possible ...
I have an arduino nano connected to a stepper uln2003, with a motor 28BYJ-48 of 5volts .
The wiring:
Arduino Nano:
(30) and (29) powers the board
(D4) to (D7) goes to the stepper motor signal
(04) GND and the (27) +5V powers the stepper driver uln2003 and the motor
(D9) and GND is for the microswitch
I use this to rotate a gyro watch winder that i download from thingiverse, by the user Gene Fusco
The program makes 10 turns clockwise and stops through a microswitch, then for 40 minutes stop, then turns 10 times anti-clockwise and stops again 40 minutes...
Send file too...
Always this ..
Works really well...
But.....
There is a problem...
The motor heats up and the part that I use to rotate is made of PLA, the heat that comes out of the motor causes the PLA to start to be deformed and spoils the part ....
Is there a way through code to turn on/off the current that goes to the uln2003 board in that 40 minute period?
You could use a relay, or a transistor, to make/break the 5V connection to the motor card.
Or you could try this - when you are done winding, make D4 to D7 low, that will turn off the coil drivers, so no motor current flows and the motor doesn't heat up.
Just need to copy and paste in the end of the file?
Or has to be in a specific place?
Sorry to ask but this is all new to me...
Definitions can go where you like with Arduino, but you put the calls to the functions in the correct places.
The functions are named logically so you can understand how to use them.
