hi !! i was using my arduino uno and suddenly it turns off !! when i connect it with usb cable it works 5/5 but when i connect it with jack (serial 6 AA battery) the power green led is very low and i got only 2V in output pins 5V and 3V !!
Does anyone have any ideas, where the problem can lie?
But it's nothing special. In theory anything with more or less those characteristics will work.
Another option is to get a LM7805 regulator. Cut a USB cable in half and connect the output of the regulator to the red/black wires of the cable. Connect that to the Arduino USB connector.
ronny441:
ronny441:
Bad advice, the bootloader has no relationship of having low Vcc voltage when using external power. Also board works on USB so how can bootloader be bad?
More testing could help. With the battery pack plugged in and the board not plugged into USB what voltage do you read between the arduino Vin and ground pin?
