power problems with ground
i have an lcd hooked up to my arduino uno, it is using the 5v on the arduino, i am trying to hook up a button and i need to use the 3.3v on the arduino, but whenever i put the other ground that i need for the button in, the lcd stops working. i could take out the 3.3v pin and the ground pin would still make the lcd stop working. if i put ether one of them on an external power source they don't work. any solutions.
the image wont upload correctly but here is the diagram url:
duplicate thread
https://forum.arduino.cc/index.php?topic=683122.0
criticalduck:
Screenshot by Lightshot
This is your picture
your code?
Pin A5 is directly connected internally to SCL, use a pin besides A5 for button (NOT A4), your button is short circuiting 3.3V directly to GND.
Not to mention why are you trying to use 3.3V for a switch which can only be ON / OFF?
Why not simply use a digitalRead for that on a pin with an internal pull-up?
Then you can just connect the switch to ground, and no need for the external pull-up or the 3.3V connection.
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
OR
http://forum.arduino.cc/index.php/topic,148850.0.html.
