power regulator for Xbee?
hi all,
I am working on a project and I am planning to use Xbee radio modules. However. I need some features that the Xbee shield does not provide, and therefore I decided to have a PCB built that will include several components (Xbee + additional circuitry, AC/DC adapter, MAX232 chip for serial communication...)
I have some doubts regarding the Xbee circuitry required... I have read everywhere that I need a power regulator to supply the Xbee chip with 3.3Volts... But why can´t I simply use the Arduino 3.3V pin?
In case I do need a specific regulator for this, what the requirements would be? Of course I need an output power of 3.3 Volts, but I´m not sure about the minimum/maximum output current... any help?
And also, I have already seen several datasheets and I noticed that I normally need a number of capacitors around the power regulator... I am quite a newbie in electronics and I never liked working with capacitors, can I just assume that the circuit that manufacturers provide will work with my Xbee or do I need something different?
Thanks a lot folks!
Unfortunately, typical current consumption of the Xbee modules is over 200mA when transmitting, an the Arduino 3.3V pin only provides about 50mA.
Yes. Your requirements are pretty simple. It should accept 5V as an input (or 6-20V on Vin?) and output 3.3V at up to 400mA or so (to be safe.) A lot of people are using (and apparently happy with) the LD1117 type regulators here.
Thanks a lot :D
You really helped me out here!
Mm well now I realize I may have an additional problem with the AC/DC transformer that I am going to use... its max output current is 444mA. Do you think it will be enough for my node? (It consists of the Xbee+regulator, a max232 serial interface and a Arduino Duemilenova board)
"444mA"?! that's a lot of significant digits for a power supply! In any case, it sounds OK. The Arduino itself is well under 100mA, and the max232 is "small" (~10mA, probably depending on loading of the signal lines.) So it sounds pretty much "just right."
Ook, thanks a lot again :slight_smile:
I make a board that integrates an Arduino compatible design with an XBee. I use an 800mA 3.3V regulator (MC33269) to power everything. This gives plenty of current for most applications. The schematic is in the datasheet at http://wiblocks.luciani.org/ZB1/index.html
(* jcl *)
www: http://www.wiblocks.com twitter: http://twitter.com/wiblocks blog: http://luciani.org
