So I am looking at a data logger and irrigation control.
I have answered and specified most the equipment already but the one question I have remaining is that of the analog sensors. I want to use 6 water level sensors, at least 4 soil moisture (hygrometer) and then a I would love to use a windspeed sensor input as well.
With my understanding the system can only supply 200mA for the analog system, I am overcoming the minimum supply by using the power input jack with a 12V 1 A power supply. But all the sensors are 4-20mA therefor if all reach the 20mA signal more than 200mA will be drawn.
Could these be supplied from another 5V source and the GND be bridged to create a common ground as done with other systems? >:( I read this should not be done for the 8 relay module so assume it can also not be done here?
