Power save with Pro Mini, PIR Sensor, and RF Transmitter (External 4 x AA Batts)
Just completed my first project and all is working well. I created a wireless motion sensor that control the lights in my kids room. The only problem is the batteries in the motion sensor only last about 5 days. Not going to work as a long term solution; I’ll end up spending more on batteries than I do on the wasted electricity by them leaving the lights on all the time. Below is my hardware configuration:
Transmitter:
Arduino Pro Mini, ATmega328, 5v
PIR Sensor
433mhz RF Transmitter
Powered by 4 x AA batteries
Receiver:
433mhz RF receiver
120v relay to power the overhead light
120v to 5v buck converter to power the Arduino
Here is the working sketch for my Transmitter:
// Wireless PIR Transmit
#include <VirtualWire.h>
//the time we give the sensor to calibrate (10-60 secs according to the datasheet)
int calibrationTime = 45;
int led_pin = 13;
int transmit_pin = 4;
int pir_pin = 9;
int val = 0;
int pir_state = LOW;
  vw_set_tx_pin(transmit_pin);
  vw_setup(4000); // Transmission rate
  pinMode(led_pin, OUTPUT);
  pinMode(pir_pin,INPUT);
  //give the sensor some time to calibrate
  Serial.print("calibrating sensor ");
    for(int i = 0; i < calibrationTime; i++)
       Serial.print(".");
    Serial.println(" done");
    Serial.println("SENSOR ACTIVE");
    delay(50);
  char msg[1] = {'0'};
  // Get sensor value
  val = digitalRead(pir_pin);
  // Change message if motion is detected
  if (val == 1)
      msg[0] = '1';
      digitalWrite(led_pin, HIGH); // Flash a light to show transmitting
      vw_send((uint8_t *)msg, 1);
      vw_wait_tx(); // Wait until the whole message is gone
      if (pir_state == LOW)
        Serial.println("Motion detected!");
        pir_state = HIGH;
     msg[0] = '0';
     digitalWrite(led_pin, LOW);
     if (pir_state == HIGH)
       Serial.println("Motion ended!");
       pir_state = LOW;
And the Receiver:
// Relay Receive
//the time when the sensor outputs a low impulse
long unsigned int lowIn;
//the amount of milliseconds the sensor has to be low
//before we assume all motion has stopped
long unsigned int pause = 5000;
boolean lockLow = true;
boolean takeLowTime;
// Pins definition
const int led_pin = 13;
const int receive_pin = 5;
int relay_pin = 9;
   Serial.begin(9600); // Debugging only
   // Initialise the IO and ISR
   vw_set_rx_pin(receive_pin);
   // Start the receiver PLL
   vw_rx_start();
   // Set LED and realy pins
   pinMode(relay_pin, OUTPUT);
   digitalWrite(relay_pin, LOW);
   uint8_t buf[VW_MAX_MESSAGE_LEN];
   uint8_t buflen = VW_MAX_MESSAGE_LEN;
   // Check if a message was received
    if (vw_get_message(buf, &buflen))
      if(buf[0]=='1')
        digitalWrite(led_pin, HIGH);   //the led visualizes the sensors output pin state
        if(lockLow)
          //makes sure we wait for a transition to LOW before any further output is made:
          lockLow = false;
          Serial.println("---");
          Serial.print("motion detected at ");
          Serial.print(millis()/1000);
          Serial.println(" sec");
          delay(50);
         takeLowTime = true;
     if(buf[0]=='0')
       digitalWrite(led_pin, LOW);  //the led visualizes the sensors output pin state
       digitalWrite(relay_pin, HIGH);
       if(takeLowTime)
         lowIn = millis();          //save the time of the transition from high to LOW
         takeLowTime = false;       //make sure this is only done at the start of a LOW phase
       //if the sensor is low for more than the given pause,
       //we assume that no more motion is going to happen
       if(!lockLow && millis() - lowIn > pause)
           //makes sure this block of code is only executed again after
           //a new motion sequence has been detected
           lockLow = true;
           Serial.print("motion ended at ");      //output
           Serial.print((millis() - pause)/1000);
           delay(50);
In my search for ways to save battery power by putting the arduino in to a sleep state, I found information on pin change events and interrupts from this site:
So, I tried to combine some of that code with my pre-existing transmitter code and came up with the following that does not work:
#include <Ports.h>
#include <RF12.h>
#include <avr/sleep.h>
#include <PinChangeInt.h>
ISR(WDT_vect) { Sleepy::watchdogEvent(); }
int led_pin = 13;
int pir_pin = 9;
int val = 0;
  PRR = bit(PRTIM1);                           // only keep timer 0 going
  ADCSRA &= ~ bit(ADEN); bitSet(PRR, PRADC);   // Disable the ADC to save power
  PCintPort::attachInterrupt(pir_pin, wakeUp, CHANGE);
void wakeUp(){}
  // Get sensor value
  if (val == 1)
      msg[0] = '1';
      pir_state = HIGH;
   msg[0] = '0';
      pir_state = LOW;
  Sleepy::powerDown();
I am a programming novice, with the exception of MS VB. I do know from my research that Delay() does not work when using interrupts and I removed them but still no luck. Appreciate any advice that can get me back on track.
Sean
