Power saving mess with PWM Output
Processor: ATtiny85
Clock: Internall 1 MHz or 8 MHz depending on performance results
Description:
Button1 - Switch effect mode (STATIC, FADE_SLOW, FADE_MEDIUM, FADE_FAST)
Slider Pot - Read analog value to set brightness
LED1 - Light Source
Problem:
When PWM is 255 it work well (no flickering) but when starts to fadein/fadeout LED keeps flickering (ON/OFF at PWM value).
If i disable power save methods it works well, so i guess the power saving is cutting off PWM when on sleep.
Theres anyway to keep PWM working when on deep sleep?
Project:
#include <avr/sleep.h> //Needed for sleep_mode
#include <avr/wdt.h> //Needed to enable/disable watch dog timer
// Utility macros
#define adc_disable() (ADCSRA &= ~(1<<ADEN)) // disable ADC (before power-off)
#define adc_enable()  (ADCSRA |=  (1<<ADEN)) // re-enable ADC
#define BUTTON_EFFECT_PORT DD3
#define POT_ANALOG_PORT A2
#define MOSTFET_PWM_PORT DD0
enum EFFECT_MODE {
  EFFECT_MODE_STATIC = 0,
  EFFECT_MODE_FADE_SLOW,
  EFFECT_MODE_FADE_MEDIUM,
  EFFECT_MODE_FADE_FAST,
  EFFECT_MODE_MAX
byte effectMode = EFFECT_MODE_STATIC;
unsigned short brightnessOld = 0;
byte watchdogSleepScale = 5;
byte fadeCycle = 0;
bool fadeIn = false;
ISR(WDT_vect) {
//Sets the watchdog timer to wake us up, but not reset
//0=16ms, 1=32ms, 2=64ms, 3=128ms, 4=250ms, 5=500ms
//6=1sec, 7=2sec, 8=4sec, 9=8sec
//From: http://interface.khm.de/index.php/lab/experiments/sleep_watchdog_battery/
void setup_watchdog(int timerPrescaler) {
  if (timerPrescaler > 9) timerPrescaler = 9; //Limit incoming amount to legal settings
  byte bb = timerPrescaler & 7;
  if (timerPrescaler > 7) bb |= (1 << 5); //Set the special 5th bit if necessary
  //This order of commands is important and cannot be combined
  MCUSR &= ~(1 << WDRF); //Clear the watch dog reset
  WDTCR |= (1 << WDCE) | (1 << WDE); //Set WD_change enable, set WD enable
  WDTCR = bb; //Set new watchdog timeout value
  WDTCR |= _BV(WDIE); //Set the interrupt enable, this will keep unit from resetting after each int
unsigned short readBrightness(bool to255 = false)
  return to255 ? map(constrain(1023 - analogRead(POT_ANALOG_PORT), 0, 1023), 0, 1023, 0, 255) : constrain(1023 - analogRead(POT_ANALOG_PORT), 0, 1023);
void readEffectMode()
  bool pressed = false;
  while(digitalRead(BUTTON_EFFECT_PORT) == HIGH)
    analogWrite(MOSTFET_PWM_PORT, LOW); // Disable LEDs to user know something is happening
    pressed = true;
    delay(50); // Wait for LOW
  if(!pressed) return;
  if(++effectMode >= EFFECT_MODE_MAX)
    analogWrite(MOSTFET_PWM_PORT, brightnessOld); // Restore brightness
  fadeIn = false;
  fadeCycle = 0;
  adc_disable(); // ADC uses ~320uA
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);
  sleep_enable();
  pinMode(BUTTON_EFFECT_PORT, INPUT);
  pinMode(MOSTFET_PWM_PORT, OUTPUT);
  setup_watchdog(watchdogSleepScale); //Setup watchdog to go off after 1sec
  sleep_mode(); //Go to sleep!
  // Check Here
  adc_enable();
  // Select the effect mode
  readEffectMode();
  // Read brightness from slider pot
  unsigned short brightness = readBrightness(true);
  if(effectMode == EFFECT_MODE_FADE_SLOW || effectMode == EFFECT_MODE_FADE_MEDIUM || effectMode == EFFECT_MODE_FADE_FAST)
    // Set sleep time
    watchdogSleepScale = effectMode;
    if(fadeIn) // 255 to 0
      if(fadeCycle > 0)
        fadeCycle--;
        fadeIn = !fadeIn;
        fadeCycle = 1;
    else      // 0 to 225
      if(fadeCycle < 255)
        fadeCycle++;
        fadeIn = !fadeIn;
        fadeCycle = 254;
    analogWrite(MOSTFET_PWM_PORT, map(fadeCycle, 0, 255, 0, brightness));
  else // EFFECT_MODE_FADE_STATIC
      if(abs(brightness-brightnessOld) >= 5) // Only change if increment justify
        analogWrite(MOSTFET_PWM_PORT, brightness);
        brightnessOld = brightness;
No.
Sleep turns the clock off, that's what saves power... CMOS power dissipation is proportional
to clock speed and voltage squared, basically.
Use IDLE.
Jiggy-Ninja:
Use IDLE.
Using IDLE option solved my problem.
There's any table i can see comparing power modes?
sn4k3:
Section 7 in the datasheet.
