Hi!
I'm building an audio data logger powered by batteries and need to minimize power consumption. For redundancy, I’m using at least 2 SD card modules and want to control their connection to Vcc, even in deep sleep mode. Has anyone tried this before? All latching circuits I find require a switch. Is it possible to control this with the chip select signal?
Some circuits I find make the ground connection available, but I would like to ennable/disable Vcc instead.
- Need to connect/disconnect SD Card modules from Vcc.
- Keep the modules disconnected on sleep mode.
- Share chip select with this control is desirable.
Thanks in advance.
