Hi there,
Most explanations regarding max current available at the 5V VCC pin recommend no more than a few hundred mA. I believe this recommendation is to prevent overheating the on-board voltage regulator. On one project I'm powering the Arduino by connecting a regulated 5V supply to one of its 5V pins (it's a Mega so has multiple 5V pins). I'm not using the on-board regulator. The power supply I'm using is capable of providing several Amps.
My question is, how much current could I draw from another 5V pin on the same board? Bear in mind that the current doesn't pass through the regulator or chip on its way from one 5V pin to another. I assume it's a direct track of copper on the Arduino board that connects all the 5V pins? So I assume the limiting factor is the capacity of the track on the circuit board and the capacity of the female header pins.
Normal current limits are based on capacity of the regulator, chip or power supply. Is it possible to damage the actual circuit board though when none of the above are limiting factors? If so any idea how much current that would take?
Thanks in advance.
BTW I know it's a weird question and that I could just draw the current directly from the power supply. It's for the sake of physical packaging and component layout that I'd like to draw it from another 5V pin.
