i have an Arduino Mega2560 board.
i must build an external board with other TTL logics, so i have a unique 5V power supply, for either my board either Arduino Mega.
can i connect my power supply directly to 5V pin of Arduino Mega board, without pass through external power connector X1 ?
i must use usb connector to communicate with PC while the board is working, what's happen to usb supply ?
usb ground jumper must be closed or leave open ?
ATmega2560 have 40mA max current output per pin, but how many outputs pins can give this current simultaneously ?
mira308sw:
It should not be a problem.
are you sure ?
if i well understand the electric schematic (http://arduino.cc/en/uploads/Main/arduino-mega2560_R3-schematic.pdf) , mosfet T1 should be ON if i power the board directly from +5V instead from connector X1, because wire VIN, i suppose, remain at 0V.
i don't want to burn the PC usb port....
johnwasser:
mira308sw:
I don't know what jumper you mean but I expect it should be unchanged from normal.
in the schematic is the pad called GROUND between usb connector and atmega16
I guess that means you can have 5 pins at max current.
i think the problem is the control of mosfet T1, it depend on state of VIN, that is 0V when the board is powered from +5V pin directly.
i read the thread you link, so there is also another problem due to voltage regulator that in this condition, is reverse powered.
i think that with 2 little modification on the board the 2 problem can be solved (i will test ASAP).
1- a diode with anode to +5V and catode to VIN to protect the voltage regulator IC1 from reverse powering.
2- remove resistor RN5D so also with 4,4V ( 5V-Vak of new diode) can trigger the comparator IC7B
modify the board in this way, let all functionality as before, it can be powered either from usb, X1 connector, and +5V, but when the last 2 method are used, usb power will remain isolated from board.
