Hi all,
I'm designing a moving sculpture, and think I have all my required power supplies figured out, but as I'm totally new to circuitry, I'd greatly appreciate any warnings/checks before I finish the project and potentially fry my equipment. Thanks!!
I will be using three small servos (two Reely S-0008s and a Modelcraft MC-410), an HR-SC04 sensor, a breadboard, and a LED light string (looking at this one: https://www.amazon.com/VISDOLL-Individually-Addressable-digital-Non-waterproof/dp/B017D2TGTS).
The servos all require 5V, as does the LED string. There is only a very light load placed on each servo, so I am estimating at most a current draw of 1A per servo, for a total of 3A. This LED string uses 0.3W, which I believe places its full need at 3A, as well. The sensor's schematics claim that it needs only 2mA. The LED will be turned off when the servos are moving, and vice versa. The sensor runs on a timed program. So I shouldn't be using much more than 3A at any given time.
Considering background power needs to all these components for their control circuitry, I'm planning on purchasing a 5V 4A external DC power supply, as well as a female DC barrel power adaptor to attach the power supply directly to the breadboard, from which I will power all of the other components, except for the Uno board, which will be USB-powered, though its ground pin will be connected to the breadboard ground.
I've read that I shouldn't need a resistor between the Uno and servos, especially as my power supply is their needed voltage, but I'm unclear if this is still the case since I will be switching them 'on' and 'off'.
Am I correct in thinking that I do not need resistors, or a regulator, for the servo?
Is it correct that I should still place a 220-440 Ohm resistor between the Uno and LED?
Because so much switching is happening, even though this is a fairly low-power project, should I look into a transistor?
Does this seem good to go?
Thanks y'all! Appreciate your time, here.
(It's maybe a more clumsy setup than if I were to solder my equipment, but money is a bit tight at the moment, so I'm trying to stay solderless.)
