I have a Kinetic artpiece i'm currently making controlling 10 stepper motors (NEMA 17 + DRV8825 Driver) simultaneously with 3 HC-SR04 Ultrasonic Sensors on a Arduino Mega 2560.
I need to know what power supply I would need to power the whole system?
And can I use the same supply to test on 1 motor or do I need to reduce the amps with a resistor?
I saw that I also need to set the Motor Current Limit on the DRV8825 Driver.
I found that you need to divide the Imax by two ,That would be 0,9V. Is that right?
Someone recommended me to -10% off the vallues to be safe ,that would make it 0,81V
This is the datasheet of the stepper motors.
I hope I gave enough information...
I’d really appreciate if someone could clarify this
Thanks
1.8 Amps is pretty high for a DRV8825. They will need heat sinks and fan cooling if you want them to run very long without shutting down. That is for quality drivers. Cheap Chinese knock offs may not work as well.
I would say to get at least a 20 Amp power supply for the steppers. 30A for cheap Chinese.
You do not need to reduce the current from the power supply to run one motor. The driver controls the current (if set properly) and will pull the current that it needs, no more.
It's hard to explain what the motors are driving...
They are driving 10 long triangle shaped beams
So there are 3 sides on each beam ,the motors need to rotate the beams on 3 different locations
The weight of each beam is still undefined because I still need to figure out what material to choose for the beams ,I could simply 3d print the beams out of PLA to reduce weight..
You need at least 9V for the drivers (that is the minimum that they will work with). Then up to the maximum that the drivers can handle (45V for the DRV8825). So in between those extremes. For the best performance (speed and torque) use higher voltage. Lower the voltage if you do not need the max. (parts that are not stressed as much so will last longer). I run my 3D printer and my 2D plotter at 12V and they work fine. I have a mini CNC engraver that I run at 12V, too, but may go to 24 V on it for better torque and cutting speed.
The voltage is irrelevant to the drivers. The drivers will compensate for the voltage, they control the current no matter the voltage. Just follow the instructions to set the coil current limit. And check and re-adjust, if necessary, if you change supply voltage.
