I am building a small IOT/Smart fan controller for the cupboard that stores some of my network gear using an ESP8266 NODEMCU board, 2x 120mm 4pin PWM PC case fans and a DS18B20 temperature sensor. While I have a solid foundational understanding of circuits, power, power loss etc, this is a bit outside my knowledge so I needed to check if I'm right here.
My original plan was to use a standard wall plug 12v 1A Power Supply, route 12v direct to the fans, then step down to power the ESP2388 via 3.3v using either a MP1584EN or AMS1117 module (eg: https://www.aliexpress.com/item/32878789479.html)
Or this https://www.aliexpress.com/item/1005005691344779.html which uses 2 AMS1117 chips but has the built in multiple output and DC Jack for simplicity
However in thinking, rather than using another 240v wall outlet, can I just use one of the existing USB3.0 ports on the device already in there?
The fans are rated at 200mA each, the thermal sensor draws less than 1mA and from what I've read, the ESP82666 draws around 160-180mA (call it 200mA for arguments sake as it will be broadcasting data at regular intervals) in normal mode, and max of 300-400mA at startup only. That's a max current of maybe 800mA (and given the fans shouldn't start without the controller that's a very worse case scenario) and a running current of maybe 600mA.
USB3.0 seems to have a regulated output of 900mA, and up to 1.5A in battery charging mode.
Question 1 - My belief is that if powering the ESP8266 via the micro USB port, I can't (easily at least) pull 5v off one of the pins. Either way, pulling 3.3v or 5v off the board and trying to step it up to 12v doesn't seem like the best option.
Question 2 - If I use USB power input, run it directly to the VIN on the ESP8266, then also run it to a step up converter like a MT3608 (https://www.aliexpress.com/item/32644511449.html) or this https://www.aliexpress.com/item/1005005763935058.html, will that work?
If the USB only outputs 900mA, I know too much will be lost in the conversion, but would it pull 1.5A? And/Or would that damage the control board?
Powering it all off USB would be ideal, otherwise I go back to plan A.
