i started a project to try and pilot a 28BYJ-48 5v stepper motor with its ULN2003 board from an arduino Nano, along with some LEDs and buttons.
I've been told that powering the motor from the arduino was a bad thing, so i took an Elegoo Power MB v2 power supply board.(it seem you can't buy it separately, so i could only find few references : Power Supply Module 3.3V and 5V - Hackster.io). I plugged its DC Jack with a 12v 2A power supply (it was for a hard drive i think), and i got now several concerns :
the chips on the elegoo gets hot! after 5~ minutes, it will stop working and go on and off as it cools and heats up again. The arduino doesn't however. I've sticked on little heat dissipators but it's not enough.
When the arduino is plugged through USB, the status LED on the power supply is being lit, even with all its inputs unplugged (!!!)
At first, the status LEDs on my motor are all off, but when i use it, 2 won't turn off even i stop rotating the motor.
the supply jumpers are set to 5v, the arduino's Vin is plugged to the +, the gnd to the - of the left part, and the motor's board are plugged the same way to the other side.
how can i fix this? thanks
