Power Supply problem with Servos and Potentiometers
I'm new to Arduino and stuff, but i am working on a project, which uses 15 Servos controlled with 15 Potentiometers.
I am using two Nanos as the micro controller.
The problem is that the servos shake really hard when connected with Pots, thry seem to work fine without them.
Am using a 6v, 4.5ah lead-acid battery.
Thanks.
Thanks.
Your welcome. I didn't see a question, though.
I didn't see any code or any wiring diagram, either, for that matter.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Can you post a link to the specs/data of your servos?
Thanks.. Tom.... :slight_smile:
