HC 05 bluetooth module
for my project.
I would like to know what kind of battery (and how many) i should use to power the circuit.
And also provide connections for the circuit.
How much current does the DC motor require? What is the rated voltage of the motor? Why use an ancient and inefficient L298 motor driver for a battery powered project when there are much better modern motor drivers available that do not waste so much power?
run time is around 3 to 5 minutes.
And details of dc motor are :
Operating Voltage(VDC): 3~12
Shaft Length (mm): 8.5
Shaft Diameter (mm): 5.5 (Double D-type)
No Load Current: 40-180mA.
Rated Speed(After Reduction): 150 RPM
Rated Torque: 0.8 Kgcm
After some research I found about switching voltage regulators. So can I use a 12v li ion battery connected to Arduino and use 6v switching voltage regulator for servo motor?
