Power Supply to control 5 Mg995 Servo
Hi Friends I´m confused, i need a power supply to control 5 of this servos(mg 995), i´m using Arduino UNO.
Especification of Servo
Operating Speed : 0.17sec / 60 degrees (4.8V no load) & 0.13sec / 60 degrees (6.0V no load)
Stall Torque : 13 kg-cm at 4.8V & 15kg-cm at 6V
Operation Voltage : 4.8 - 7.2Volts
Gear Type: All Metal Gears
Original box: NO
Color: Black
Item size: 40 * 19 * 43mm
Servo weight: 55g
I want to control 5 of this motors, to build a robotic arm, i probe connecting + of servos to a 9v, gnd of arduino to gnd of servos and the supply, but not funcion, please help me.
In the future i want to use potenciometers or analog joystick to control this motors.
Why would you use 9V for a 4.8-7.2V device?
What do you mean it doesn't function? It "should" work I suppose, even at 9V but maybe you're using a PP3 and it can't provide enough current. You need to allow 1A per servo, so 5A if they all move at once.
Or maybe it's your code, but you didn't post it so it's impossible to tell.
What do you recommend to Send current at 5 servo motors, the code that probe one of the servos if it works, but when I connect to the battery , no signal was sending the servomotor As acting crazy
Check basic function first:
  • Try using 5xAA for 6V on, as this is a given operation volts for your servos.
  • Try using only 1 servos first, and then only 2, before lining up all 5 of them.
How did you wire them and the external power source?
I found the wiring template on this page very helpfull in my first tries.
