Power supply Voltages
I burned out my Arduino by not changing the jumper on the kit supplied power supply. I have purchased another Arduino. I plugged the power supply into a breadboard after changing the jumper. I checked the voltages with my multimeter and both sides read 8.8 vdc. I realize that this is unloaded, but is that acceptable. I really am hesitant to plug in the Arduino and use the common power rails that has the 8.8 vdc to feed the inputs on the Arduino.
  • Which Arduino Board you are using?
  • I burned out my Arduino by not changing the jumper on the kit supplied power supply.
Please share the picture of the circuit without giving power to it so that we can understand it more clearly
  • How you were powering the board?
//Arduino
