I have an arduino mini pro board and I plan on running it from a 12v deep cell battery which will also be supplying the power to other components. The recommended input power for the mini pro is 5-12v. I know batteries can at times provide a voltage slightly higher than it's rating. Would the 12v supply from a battery need to be regulated to ensure it does not past 12v or will it be fine with a direct connection.
The alternative is using your standard 9v battery to simply run the arduino and a relay - but I am not sure if it would provide the power needed to run for the 3-4 days required (the coil relay being latched for a total of 12 hrs over the entire period - the arduino - continuous) Any suggestions on the lifespan on a standard 9v to power an arduino and relay? I suppose I could wire two 9v in parallel or a pack of 6 AA.
Thanks for the input
