Power Tools Soft Start
I am making a project for my power power tools to have a soft start function when I turn on the tool.
So far I decided this settings specs.
Ramp time is 0 - 60 seconds
Kickstart is 0-100 percent power for 0.5seconds.
Right now I am using the Arduino Uno but I will adopt it with Attiny85 after it works.
I will be using MOC3052 coupled with a triac for the output.
For the input, I saw some post here that used the LTV814 from Lite-On, but i am not sure if this will detect the zero crossing of the AC power source.
I will also have some input pin to detect if the power tool was switched On.
I will be needing some help on the code soon.
code below is just a test for the analog input.
const int aiRampTime = A0; // ramp time refer to arduino board for the physical pin
const int aiKickStart = A1; // Start torque adjustment
const int diPowerOnMotor = 3; // Motor switch on
const int diAcCycle = 2; // input signal from AC source
const int doAcSource = 13; // output for Motor control
//note Ramp Time 0-60 seconds variable depends on analog input
//60 seconds equal to 3600 cycles at 60 Hz
  pinMode (diPowerOnMotor,INPUT);
  pinMode (diAcCycle,INPUT);
  pinMode (aiRampTime, INPUT);
  pinMode (aiKickStart,INPUT);
  pinMode (doAcSource,OUTPUT);
int valaiKickStart()          //read analog input and store value to valaiKickStart
{                             // Value can rannge fromn 0-1023
  int a = 0;
  a = analogRead(aiKickStart);
  return a;
int valaiRampTime = 0;
/*// read analog input and store value to valaiRampTime
{                             // convert analog inpput value to 1 minute maximum cycles
  int v=0;                    // 3.52 = 3600/1024 multiplier for 3600 cycles
  v = 3.52 * analogRead(aiRampTime);
  return v;
  // read the value from the sensor:
  valaiRampTime = 10 * analogRead(aiRampTime);
  // turn the ledPin on
  digitalWrite(doAcSource, HIGH);
  // stop the program for <sensorValue> milliseconds:
  delay(valaiRampTime);
  // turn the ledPin off:
  digitalWrite(doAcSource, LOW);
  // stop the program for for <sensorValue> milliseconds:
Exactly which tools? Many modern motors have electronic controls that will behave badly when you try to apply external control. Older ones will also behave badly when controlled with a triac.
If you're applying a kickstart to get the motor moving, then that defeats the purpose of the soft start. Once the kicker has it moving, then it's started and will probably run best at full power.
Do you have any experience in building mains-powered projects?
Hi Morgan,
I already tested starting a motor using triac as a switch.
I am new with arduino programming but for the schematic i can understand it clearly.
Are you good? Can you help me with this project?
You need to start from the basics. Can you get the triac to control the speed? Can you make it ramp over time? Can you write a state-machine that does all the actions you need?
The basics are covered here: Arduino Playground - ACPhaseControl
For any inductive load, you’ll need an r/c snubber across the triac.
Zero Cross detecting 120Hz.
