I'm hoping the following is possible, for a project of mine.
I have some Arduino Pro Mini's that I want to use in very small spaces (so far so good). But now here's the thing, the arduino's should be completely powered down, not using any power at all (so sleep is not an option) and at the push of a button, power up, do setup() and loop() and then completely power off again..
Is this possible? I will probably need specific buttons/switches or transistors to do this, but I can't find any examples.
The only way I know to do this it by using a relay, preferrably a latching relay. The button goes to the SET coil and to the Arduino. Press to set the relay and apply power, press again and the Arduino detects this and RESETs the relay, thus commiting suicide. Needs 2 pins, one to read the button and another to control the relay.
If you don't want to press again to power off then just do so at the bottom of loop. Only needs one pin to control the relay.
The above could probably be implemented with transistors with some thought.
I have a similar problem for my project, if you are interested i can post some planning schematics i threw together a few weeks ago. I haven't tested or assembled yet, it's a lower priority at this stage...
